My printer has error:0xc0620004 411:lib_micci2.c
  • 3 more comments
  • rpvmoura Jan 17, 2009
    My HP PDC 1610 is giving me back the message
    Error :0xc0620004
    411:lib_micci2.c
  • zero_thunder Jan 23, 2009
    HP OfficeJet 7310 All-in-One
    Error:0xc0620004
    411:lib_micci2.c
  • Anonymous Feb 04, 2009
    the guys at HP tech support told me to switch off the device at the wall , and the switch on the device holding down, the 'ok' and 'cancel' buttons together, until it says nvram clear ( mine said 'deriv clear' ), this is a factory reset.
    the techie told me all errors beginning in 0xc.... are to do with ink delivery system.
    it didn't work for me but it might for someone else
  • Anonymous May 14, 2009
    same error message...i wish i knew how to fix it! i've tried cleaning the cartridges, which resolved the error, but then the mintue i tried to print again, i got the very same error message. no idea how to fix this...
  • Orn Wilson
    Orn Wilson May 11, 2010
    Which machine?
    Inkworks
4 Suggested Answers
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Posted on Jan 21, 2009
SOURCE: lcd screen is flashing error:
Please try the following steps:
Make sure unit is plug directly into a wall outlet and not connected to any power strips or surge suppressors
Note : Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Your printer should be back in a working condition after this. Let me know if this has been of any help. Thanks for using Fixya.
Posted on Sep 09, 2011
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
Hp 2355 all in one error message
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
561 people viewed this question
k24674
Marvin
Marvin
