Question about JVC AM FM CD DET FACE CAR STEREO
Stereo wont work with engine on
Hi there i put a JVC stereo in my car oh about 4mths ago now and its worked great up untill today when it went off and it wont go on at all with the engine on but WILL work ok with the engine off any ideas please?
    Problem Solver:
  • 5 Answers
Best thing is to pull the radio out and check the red and yellow wires red wire is the egnition switch and your yellow is the always on for your memory if you like you can connect the red and yellow wires to the yellow one that will work with engine on or off but every time you get out the car you will need to turn the radio off manually i sugest pulling the radio out and checking the 2 leeds as far as you can it could also be a fuse gone but it wouldnt work when enging is off so not sure except check the wires your engition switch doesnt play up does it like your dash clocks go off and on while driving headlights etc? need more information please
Posted on Dec 22, 2008
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
My JVC car stereo will let me listen to the radio but when i put in a cd it wont play and 00:0000 AY flashes constantly. It started a week ago... have i pressed a wrong button?
I had the same problem, it occurred after my battery had run flat. To fix it you need to reset the unit. To do this, remove the clip-off fascia, and on the main body of the unit there small hole, just to the left of the connector. Push a narrow pointed object such as a pen nib into this hold until you feel the click. The unit is now reset and should be working properly. You'll have to retune your saved radio stations, but the cd player should now be working.
Dec 17, 2009 | JVC AM FM CD DET FACE CAR STEREO
I attach my new ipod touch to my JVC car stereo and the screen displays CANNOT PLAY. What is my problem?
Are you attaching it via usb on the deck or aux? Because if it is via usb the touch is probably not supported.
Nov 08, 2009 | JVC AM FM CD DET FACE CAR STEREO
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
JVC Car Stereo Very Noisy
Bought new JVC stereo and installed it. No noise, no cracking. 1st stereo must have been bad.
Jun 08, 2008 | JVC AM FM CD DET FACE CAR STEREO
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
Lighting problem JVC KD-LH2000
If your unit is a "flip face" design then I would suspect that the flat ribbon cable that goes between the flip face and the main board has lost at least one of the leads and that the cable needs to be replaced. Try Partstore.com for a replacement. Good luck.
Jan 21, 2007 | JVC KD-LH2000 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
139 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
