I had Windows Vista removed from my Gateway computer and installed Windows XP. Now the keyboard won't work. Any suggestions?? Thanks for your help.
  • pgmadhav
    pgmadhav May 11, 2010
    Please elaborate the problem
  • 111 Answers
If your pc is new the problem is in the drivers boot your pc in bios if your does not have a keyboard error it is the vista drivers got to the keyboard manufacturers site and check for drivers, also when installing xp you must use the pro version for some new pcs to funtion correctly when downgrading from vista to xp
Posted on Dec 19, 2008
  • 916 Answers
See if there is a keyboard driver update from Gateway for windows xp. This may be the problem.
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Gateway dx4300-11 won't power on after put in
Is the Gateway DX4300 having problems while installing the drivers after sleep mode
or does it have these problems during the laptop is turned on.
Always make sure you download the right drivers for your system.
If you installed Windows Vista after you had formatted the system and now your trying
to install them you might want to go on another system and download all of the drivers either on an external hard drive or an SD card so everything can be accessible.
After you install Windows Vista or 7 make sure that the compatibility mode is selected while installing the drivers.
Most of Gateway drivers are Windows XP so you have to go and right click on each and every driver and change the compatibility mode to Windows XP SP2 that way when you let it install then Windows Update will activate to perform updates for hardware drivers and software applications. It will also get the KB updates for your computer.
This will probably fix the sleep mode and improve it too.
1. Go on Gateway's site
2. Download the DX4300-11 drivers and make sure its directly from
Gateway on a SD card or external hard drive.
3. Change the compatibility mode to Windows XP SP2
and let it run as administrator.
Each driver will then install and then you will fully use
your computer's capability.
After the drivers are installed then change your power options
as it will continue to install your drivers.
Check to make sure that your battery is fully charged and is plugged in
if it is. If not plug in for charging the battery.
If all fails then you will need to replace the motherboard.
Sep 26, 2011 | Gateway Computers & Internet
Is it possible to move Vista from one computer to another without the disc? I have a product key for the Vista that was installed. The original OS was XP and Vista was purchased and installed. I got this...
It can be done if:
1) the i386 directory was installed on the first PC
2) the first machine is being scrapped (must happen or you violate the Microsoft EULA)
3) you can burn a copy of the Vista i386 directory
There are additional things to do to complete the process, but the answers to the above will determine if it can be done.
Aug 03, 2011 | Computers & Internet
I am currently trying to install win7 ultimate on my gm5632e and i am unsure which drivers i need to pre install during instillation to make it work. if you could give me a link to some instuctions or to...
Your computer Gateway GM5632e was designed for Windows XP and Vista. You may be successful installing Windows 7 Ultimate on this computer but you will have difficulties finding the right driver for the TV Tuner which was developed and manufactured by Gateway themselves. As always, drivers and sofrwares are limited from the manufacturers release. On the other hand, Windows Vista 64bit has having some issues with its updates. Windows Vista 32bit version can only work if your installer has service pack 1 with it. I suggest, have Windows XP install on your computer as it is stable comparable to the performance of Windows 7. It may not look like Window 7 but surely, Windows XP can still maximize your computer's capability.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
May 11, 2011 | Computers & Internet
Xp installation problem
Goto bios - disable sata operations and select hard drive type as normal, disable ahci, disable acpi
May 29, 2010 | Gateway T-6330U Notebook
the system doesn't accepts the lower version of windows if you are having the latest version than xp. for thi you must format the two OS softwares and first install lower version i.e., xp and then by dual booting you can also install vista or windows 7. then you can use both versions..
Drivers for ethernet card for gateway 6433 laptop
That unit has multiple drivers depending on os and original configuration as shipped. All are available at the mpcdrivers.com website at the following links.
http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN2.exe - Windows Vista Intel Wireless Network Driver version: 11.1.0.86
Supports: Windows Vista (32-bit)
Note: This file contains the Windows Vista network driver for the computer models and components listed below.
3/13/2007
190,957 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN.exe - Wireless Network Driver version: Intel 10.6.0.46
Note: This file contains the Windows Vista network driver for the Gateway notebook computer models and components listed below. English, Japanese, and Spanish installation instructions are included in the file.
2/7/2007
3,633 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/LANFAQ.exe - LAN Windows Vista Driver Information
Note: This document explains the networking functionality within Windows Vista for the computer models and components listed below. English, Japanese, and Spanish instructions are included in the file.
2/1/2007
27 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/BCM40100.exe - Broadcom Wireless Driver Version 4.100.15.5
Supports: Windows XP
Note: This is the Windows XP Broadcom Wireless driver for the Gateway notebook computer models listed below.
11/28/2006
77,858 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/D00453-001-002.exe - Network Driver version: 8.26.2.3
Note: This is a Windows XP network driver for the Gateway notebook computer models listed below.
Apr 16, 2010 | SMC Realtec Network Card NERENC01
Just got a new computer with Windows 7. Old one was running XP. It doesn't appear that there are drivers for the Kensington Wireless Keyboard 64355 on Windows 7. Any suggestions?
try and see if you can install the drivers in xp compatibility mode, if windows 7 even has that. vista did. a lot of drivers from xp didnt work on vista either. thats the sole reason i havent switched from xp to the new versions of windows. good luck and hope it will work for you
Jan 15, 2010 | Kensington Comfort Type Wireless Optical...
How to remove vista from 1525 laptop and install winxp
you have to get in Bios. you will find HDD section. it must be IDE/AHCI section. you need to do IDE if you want to install XP. XP doesnt regognize AHCI SATA drives.
May 30, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Gateway SK-9922 Keyboard fastkeys don't work
You have a problem with your drivers. That keyboard is too old and I can not find any vista drivers. I can find XP and Windows 2000 drivers. The regular keys should work, but the extra keys that are not standard on all keyboards, like the cut, paste, and volume controls should not work.
If you want a keyboard to have those functions, then you need to buy a newer keyboard that has vista drivers.
Nov 13, 2007 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
Alun Cox
David Payne
David Payne
