Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
Unable to connect to comcast using a Motorola SBG900 cable modem
Not able to get a connectivity utilizing a USB connection. Not certain I have the necessary LAN settings in place to do the connection. First time user of a Cable Modem through comcast.com.
Also, tried an ethernet connection with the same results. Getting a confirmation on the modem/router setup that the setup was successful but no connectivity and Comcast can't see where I am connected also.
  • 86 Answers
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
Posted on Jan 20, 2008
  • 31 Answers
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Posted on Apr 09, 2009
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
  • 40 Answers
SOURCE: Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Posted on Apr 10, 2009
zazonker
  • 68 Answers
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Posted on Jun 08, 2009
I have a Motorola Surfboard SBG900 wireless router and my provider is comcast. Comcast came out and changed some wiring and connections but i continue to loose connection, every couple of minutes. What...
i had the same problem. it turned out the power to the modem was shorting just enough to throw me off and have comcast resetting the ip address and connection. i fixed it by getting a new power supply and plugging it in to a really good strip bar. hope this helps
May 28, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Bought on eBay, trying to setup with comcast. See wireless signal but can't connect to the internet. I got to the configuration page and changed the SSID and setup WEP but the internet is not working.
have you tried connecting an ethernet cable directly to the modem to see if the internet is working that way? Have you considered contacting comcast as they can make sure its on your end or their end. Use this faq to help you. If you need further assistance please let me know.
http://www.comcast.com/Customers/FAQ/FaqCategory.ashx?CatId=578
Thank you,
Lee
Jan 14, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900 Connected but not sending and recieving.
its your modem dude.... try to connect it to your main connection..
Jun 16, 2009 | Arris SURFboard SBG900 (49402201900) Modem
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Cannot get SBG900 MODEM TO CONNECT TO INTERNET
I can not connect to DSL using Cable One for provider and having a few problems with the wireless connection.I am using HP Pavilion.
Dec 30, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Software
Yes you can use USb modem, you need to uninstall modem software, disconnect modem and reinstall software configuring it as usb. Start installation with modem disconnected and follow User Guide SBG900
Note: usb modem is much slower than ethernet modem (even if you use same machine) . Instead of using modem as usb I suggest using an external Usb Network adapter.
Regards
Apr 21, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Can not connect web cam and view outside of home network
Try to see your modem config and send the data.
regards
Jan 06, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SURFboard SBG900 loss ethernet connection
Please remove the program of your router and re install it again and it will work..
Good luck
Johnson
Jan 03, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
803 people viewed this question
Top Arris Computers & Internet Experts
Greg Ulan
Robbie Goodwin
RS Technology...
RS Technology...
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
