2008 Ford F-250 Super Duty Logo
Posted on Aug 17, 2012
Trouble code P2084
Code p2084
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
739
Points
How to fix the code p2084 on a 2009 F250 super duty?
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 05, 2012
SOURCE: where is the egr valve temperature sensor on engine ?
It is part of the EGR valve
Locating the code 2084 on my 2008 fordf350 super duty dually
P2084 means there is an issue with the exhaust gas temperature sensor. Bank 1 sensor 2.
P0741 means Torque Converter Clutch Circuit Performance/Stuck Off.
Two totally unrelated issues.
Your testing must measure the voltage from the sensor and a possible replacement torque convertor may be needed.
P0483 P2609 on Cummins won't start.
'year make model' in all questions please as first 3 words. Some codes are special to a certain vehicle.
P2609 code definition A P2609 trouble code indicates that the PCM has detected abnormal voltage readings from one or more of the intake air heater circuits. This particular trouble code is most often associated with trouble codes P2604, P2605, P2606, P2607, and P2608.
P2609 OBD-II Trouble Code: Intake Air Heater System ...
P0483 OBD-II Trouble Code: Cooling Fan Rationality Check ...
https://www.yourmechanic.com > Articles
P0483 code means that the cooling fan has been commanded to turn on or off, but the voltage reading indicates that the fan did not respond.
1helpful
Air bag sensor keeps flashing
If a concern is detected, the air bag control module will communicate by flashing the warning indicator. A diagnostic trouble code (DTC) is logged by the air bag control module in a nonvolatile memory. For additional information, refer to Diagnosis and Testing in this section.
Lamp Fault Codes (LFC)
Item Part Number Description 1 One flash cycle: Driver air bag trouble code 2 Two flash cycle: Passenger air bag trouble code 3 Three flash cycle: Trouble code common to both driver and passenger air bag circuit 4 Four flash cycle: Safety belt pretensioner trouble code common to both driver and passenger pretensioner circuits 5 Five flash cycle: Driver side air bag trouble code 6 Six flash cycle: Passenger side air bag trouble code 7 Not used 8 Not used
4helpful
Airbag flashes 10 times misses a flash then repeats
Try clearing the codes & see if it returns. I do not see a code fault 10. Starts at 12.
Section 01-20B: Restraints, Passive — Supplemental Air Bag System 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual DIAGNOSIS AND TESTING Diagnostic Trouble Code Clearing Procedure to Clear Diagnostic Trouble Codes from Diagnostic Monitor Non-Volatile Random Access Memory.
Normal Operation
The air bag diagnostic monitor (14B056) continually checks the air bag system for readiness. When a fault condition is detected, the DTC associated with that fault is stored in the air bag diagnostic monitor's Non-Volatile Random Access Memory (NVRAM). After writing the DTC to NVRAM, the air bag diagnostic monitor signals the fault by flashing the appropriate diagnostic trouble code on the air bag indicator. The diagnostic trouble code written to NVRAM is permanently stored in the air bag diagnostic monitor until cleared by the diagnostic trouble code clearing procedure.
  • Upon each cycle of the ignition switch (11572) , the air bag diagnostic monitor checks for diagnostic trouble codes written in NVRAM. If any diagnostic trouble codes exist in NVRAM, the air bag diagnostic monitor will then check to see if these fault conditions are still present.
  • If the conditions of the diagnostic trouble code in NVRAM are still present, then the air bag diagnostic monitor will use the air bag indicator to flash out the diagnostic trouble code number that was written in memory.
  • If the conditions of the diagnostic trouble code are not still present (indicating an intermittent or serviced fault), the air bag diagnostic monitor will use the air bag indicator to flash out a DTC which is the sum of the diagnostic trouble code in NVRAM plus 40.
Example: Due to corrosion, high resistance develops on the driver side air bag circuit. The air bag diagnostic monitor stores a diagnostic trouble code 32 in NVRAM. Upon each cycle of the ignition switch , the air bag diagnostic monitor checks the resistance of the driver air bag circuit.
  • If the resistance is still high, the air bag diagnostic monitor causes the air bag indicator to flash out a DTC 32.
  • If the resistance falls within the normal range due to service or an intermittent condition, the air bag diagnostic monitor causes DTC 72 to be flashed on the air bag indicator.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVRAM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (TAN/RED STRIPE) to Circuit 57 (BLACK). This short must be released within 25 seconds after the diagnostic monitor tone sounds. Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
