Question about Silex Technology Silex SX-200 - Print server - Hi-Speed USB / parallel - EN, Fast EN, EtherTalk - 10Base-T, 100Base-T... (SX-200-0211) Print Server
Silex sx-200 loosing wireless signal intermittantly
We are having issues with 4 silex sx-200 print servers loosing its wireless signal no matter what location we are at.
this ends up causing problems with docs being left in the queue.
the printer and print server are approx 40 feet away from each other.
when I have the printer and print server approx 6 ft from each other I get a signal strength anywhere from 27% to 87%.
Is there a known issue with these print servers and its signal strength?
if there is , is there a fix? does it need a firmware upgrade?
your help would be appreciated
System error found
Hope this will help someone else:
InWindows' Device Manager (devmgmt.msc), the SXUPTP driver was showing as disabled.Windows gave a warning that the device was known to have stability issues. Ifound out that SXUPTP is a driver from a company called Silex. Silex makesnetwork USB hubs, so I assume that the Belkin hub is a rebranded Silex hub.
In order to update the Silex driver follow these steps:
1. Close the Belkin network hub's tray application.
2. Download the latest version of SX Virtual Link(sx-virtual_link_win_3120.zip).
3. Extract all of the files.
4. In Windows Explorer, navigate to sx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVistaX64if you are running a 64 bit OS, orsx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVista if you arerunning a 32 bit OS.
5. Right-click on "Sxuptp.inf" and select "Install" fromthe menu.
The driver will be installed and the warning icon in the device manager shoulddisappear. You may need to reboot for the changes to take effect.
Nov 03, 2013 | Belkin Computers & Internet
Silex sx-2500 cg
What exactly is your question?
Oct 30, 2013 | Silex Technology Ricoh Wireless Bridge...
2004 dodge sx automatic intermittent start problems
If it starts with booster cables, it points to bad electrical connection or discharged battery , clean battery posts and terminals . have battery tested with high discharge tester.
Nov 30, 2017 | Dodge Cars & Trucks
6T04 Adapter failure
That 6to4 adapter has been a problem for as long as I have been aware of it but I only have that issue when I use my print server. I don't believe the 6to4 is your actual wireless. Are you using a wireless print server?
Sep 04, 2009 | Packard Bell 1580509280 Network Adapter
I want to connect the print server ESI9132079.i need drivers for this print server.
hi,
Download and read the manual of this print server.
http://silexamerica.com/us/products/pdf/xtnd/dx-sx.pdf
You only need the actual printer drivers not the print server driver (there is no such thing for print server drivers). Once you connect to network and to Print server, you should be able to see what brand printer is connected to server such as HP, Epson, Fujixerox, Samsung, etc.
Hope this helps
Cheers
Shafie
May 08, 2009 | Troy ExtendNet SX Print Server
I can not print
I had a similar problem that was caused by my firewall. I was able to get it to print fine but could not get it to scan.
To test, try temporarily disabling your firewall. Bringing up SX Virtual Link then search for devices. If you can find your Canon, that's the key. Silex has instructions on how to get around some of the firewalls on their web site. I had to figure out how to get around AVGs firewall on my own. Check out silexamerica.com.
Reply to this message if it doesn't work or if you need instructions for the firewall problem.
Good luck helena!
- Susan
May 03, 2009 | Canon Silex Pricom C-6200U (0297V462)...
Silex sx-200 print servers loosing its wireless signal
I work with Silex and can send you the latest firmware release candidate for the SX-200 that includes changes that improves the performance of the unit's wireless radio. Please email me at fponio@silexamerica.com with your full contact information with reference to this post and I can reply with the updated version file and instructions on how to load this file on your unit.
Thank you.
Francis Ponio
Technical Support
Silex Technology America
Dec 19, 2008 | Silex Technology Silex SX-200 - Print...
MF6550 print server
The Silex C-6700WG wireless print server works great. You can use all of the functions with this print server.
Jul 29, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Problem with Canon I-SENSYS MF 4150
After several days of researching the same problem for the MF4150, the conclusion is that you have to use an Axis or Silex brand print server developed specifically for Canon. Both have been reported to provide Print/Scan/Fax multi-functionality, but it seems Silex is the one Canon really supports (it's only sold on their website) and is most likely to be the least problematic.
Jan 05, 2007 | Edimax PS-1205UWg (PS1205UWG) Print Server
Silex Technology Silex SX-200 - Print server - Hi-Speed USB / parallel - EN, Fast EN, EtherTalk - 10Base-T, 100Base-T... (SX-200-0211) Print Server Logo
51 people viewed this question
Top Silex Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Silex Technology Computer and Internet Expert? Answer questions, earn points and help others
