Question about IBM ThinkPad T40 2373 Notebook
Blew out new power supply right away
Where can i take my thinkpad to get worked on? Got a new power source,first one died,but it killed the new one right away.Is there somewhere I can take it to get looked at?I live in illinois
  • Anonymous Mar 11, 2009
    Got a new power source,first one died,but it killed the new one right away whats the problem ?
Help! Truck starts then dies right away
Alternator is not charging battery starts a car and then alternator runs all power needs...
Dec 15, 2013 | 1999 Chevrolet C/K 2500
How do i switch on the motherboard?it went off when the power supply blew off and i replaced a new power supply
When your power supply died it probably killed the motherboard too. You can test the motherboard's viaablity with a stand alone video card.
Aug 17, 2012 | Mercury P4VM800M7 Motherboard
I have the Samsung 46 in LCD TV LN46A650. I noticed the other day the left side of my screen was darker than the right side and there was also a pink hue to the left side. This only occurres when I turn...
If u unplug the tv power supply source and replug it back in the tv problems it go away?Yes.The power supply board is the source of the problems,it have dying capacitors parts.U have all the tools and understanding basic electronic also can do basic soldering?Yes,check carefully in the whole power supply board for dying capacitors parts,capacitors are dying are alway bulges or puffing up on to it tops.Replace all the dying capacitors with new capacitors with the same Micro Ferit and the capacitors voltages like 5 to 10 higher voltages more than the old capacitors for better heat resistances.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
My ibm thinkpad G40 wont turn on
Check the power source, plug it into the wall don't try to just run off the battery. If it still does not turn on plugged into a working outlet the power supply needs to be replaced.
May 06, 2010 | IBM ThinkPad G40 2388 Notebook
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
The dog decided to chew the power supply cord the other day, and I continued to use the thinkpad until the battery died. I fixed the cord today and have approx 19 V coming from it to the computer. The...
Remember this is a DC output...Make sure you have the right wire hooked together. What I mean is if you soldered the wires make you didn't reverse the negative and positive. Otherwise look for a new power supply.
I have had to replace mine a few times.
Oct 10, 2009 | IBM ThinkPad R40 2722 Notebook
THINKPAD Dead!!
There are no fuses in the thinkpad there are power transistors and i would think that the main transistor has blown. If a USB plug was faulty it is possible it shorted out when you connected the canera and blew the transistor. It could be quite expensive to have this repaired, especially considering you can buy a toshiba L300 for about $400.
Aug 16, 2009 | IBM ThinkPad T40 2373 Notebook
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
THINKPAD LAPTOP NOTEBOOK T41 no power
ggiamber,
This is a common problem on the T4x series. Motherboard usually dies after a couple of years. Youĺl need to look for a new motherboard or have it fixed.
Mar 27, 2009 | IBM ThinkPad T40 2373 Notebook
Soldered in new fuse, blew it right away...whats a good upgrade?
A new power supply will fix your problem, and when the fuse blows do not replace it. It blows to protect your computer. please replace with a new power supply.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Oct 28, 2007 | Okia / 450-Watt / ATX / 80mm Fan /...
IBM ThinkPad T40 2373 Notebook Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
