Question about iLO DVDR05 DVD Recorder
Disc compatability My DVR won't accept Sony brand DVD+R discs. I can format the disc for use, but when I go to record, I get the following message: "This disc may not be written for it is not in the supported media list." The speed compatability is 1x - 16x. Memorex and Maxell brands work fine, but the Sony brand won't. Should I try updating the firmware? Thank you.
  • 32 Answers
Re: Disc compatability
Why upset yourself?,my friend, you are going to get the "Electroncoodies" Use the brand [Memorex & Maxell] that works.
Posted on Jul 25, 2007
0 characters
3 Points
My Philips DVD Recorder does not accept a DVD disc shows no disk. The DVD disc does not revolve. A CD disc revolves but shows junknown
Could be that you are using the wrong type of DVD ? There are two formats DVD+R, DVD+RW etc and DVD-R, DVD-RW etc. Some machines are capable of using either, others can use one of the two formats.
My other suggestion is that some machines are picky about which manufacturer's DVDs they will use.
if you have an error code this might be useful
Dvd recorder won record on DVD RW disc
Some possibly relevant answers here which suggest my answers above
Nov 06, 2015 | Philips DVD & Blu-Ray Players
I have a panasonic dmr-75v dvr and it won't read blank dvd's.i tried 3 different brands of dvd's with no luck of
This machine will only accept DVD-RAM & DVD-R Discs.
All other formats of Recordable DVD will be rejected for either Recording or Playback.
Please leave feedback.
Jun 03, 2011 | Panasonic DMRES15 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
Jun 03, 2010 | Sony RDR-VX420 DVD Recorder/VCR
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Can't record on dvd+rw disc what kind of disc do I need Thank You
There might be a firmware upgrade to allow this I would use DVD-R for full compatibility however DVD+R media from Philips is increasing in compatibility with most NON Philips and Sony players.
Feb 25, 2010 | Pioneer DVR-225 DVD Recorder
Cyberhome 1600
You might try taking the cover off and then VERY GENTLY use a q-tip swab to brush off the laser lens. Sometimes a little dust or dirt is enough to keep it from detecting the disc.
Nov 11, 2008 | Cyberhome DVR 1600 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Formatting New Disc Problems
Dec 28, 2007 | Cyberhome DVR 1600 DVD Recorder
Can't record
hi all, spanky new, ok here my problem!! i got the panasonicdmr-e55 for xmas, 3 or 4 years ago. since then and even wheni started to use it the disc i recorded on were -R phillips 4x. since then i have tried every available manufacture of 4x's u could think of and yet to this day it will only record on a phillips 4x disc. its been in the shop a few times for cleaning and upgrades and yet they haven't beable to tell why it only accepts PHILLIPS BRAND 4X. the new upgrade i recieved fromthe manufacture was supposed allow higher in x's on disc. it accepted 16x phillips only ONE TIME AND REJECTED 50 OF THEM, SINCE THEN ABSOLUTELY NO MORE 16X OF ANY KIND. ANYONE GOT A SOLUTION????? ps even tried 8x its still a no go. i can't afford anything since i'm on social security. message: UNREADABLE DISC. SUGGEST REPLACED DISC. OK SO THIS MORNING I TRIED TDK, MEMOREX, H.P. CIRCUIT CITY, AND 6 OTHER BRANDS ALL 4X NEGATIVE R, STILL A NO GO HELP, THANKS GINA
Dec 23, 2007 | Panasonic DMR-E55 DVD Recorder
iLO DVDR05 DVD Recorder Logo
118 people viewed this question
Top iLO DVD & Blu-Ray Players Experts
matt martin
matt martin
Steven Wander
Steven Wander
Level 1 Expert
Are you an iLO DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
