Question about Intel Motherboard
Gigabyte Motherboard Hey guys, I have a Gigabyte Motherboard with a Pentium 4 Processor and RDRam on the board. I have had this board for about 4 years and it finally started to give me problems. When I boot up, it will make it to the Windows XP screen and then from there the hard drive light will stay lit but the screen stays black. I found that there was a bad capacitor on the board so I replaced that and the first time it booted up, it worked but now it still gets stuck at the same place. It will boot up if I use Safe Mode, but any regular mode it gets stuck. I have ran numerous tests on it and one told me that I had a bad stick of Ram, so I took out that pair and threw in some continual ram pieces for RDRam. I also have tried about 3 different hard drives and it happens to each one on the second boot. Any help would be appreciated.
    Problem Solver:
  • 17 Answers
If it worked when you changed capacitors only once and then broke again it might be frying them or something like that. I assume you have tried resetting CMOS and reseting your bios settings to default? the last thing to try would be a reformat. but this board has had a long life and if you can afford it i would just update.
Posted on Dec 19, 2008
How to check my gigabyte mother board under warranty?
hi.there...
i read from your information and picture about your motherboard type..i think yours is not under warranty from factory anymore (GIGABYTE)
for additional information your mainboard (MB) is using old type of intel chip set (Intel 865 series) and only support intel processor type Pentium 4 with 478 pin with 533 MHz bus processor..
talking about warranty from factory GIGABYTE only give 3 years warranty only for MB with minimum chipset intel ICH 7 and up..that's mean MB must be support processor minimum 775 pin and 1155 pin or support intel Pentium D,Dual Core,Core2Duo or Core i series...
hope this is can help to solve your problem..
Aug 13, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Can the motherboard GA-8S661FXM-775 support AMD Athlon X2 CPU?
This motherboard only support this type of processor , Supports LGA775 Intel® Pentium® 4 / Pentium® D* processor FSB800 with HT technology.
For the complete details about this motherboard check this link, just click HERE.
Dec 17, 2010 | Gigabyte Computers & Internet
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
My AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Sep 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
Uppgrade to a faster processor?
Hi
Pentuim D is a processor that has 2 x cpu in one and a core 2 duo has 2 cpu's plus 1 smart core bigger cache
you can only upgrade to a E2140 or E2180 processor on that motherboard
OR replace the board with a newer type
If you want to work the actual speed for the processor of a dual core take the speed for example dual core 1.8 x 2.1 =3.78 GHz
Core 2 Duo  1.8 x 2.4 = 4.32 GHz
Sep 23, 2008 | Computers & Internet
BIOS problem!!
Why do you want to overclock it? Have you changed the cooling system? Overclocking might fry your processor if the cooling cannot keep up with the heat. Does your motherboard support overclocking? The option might be locked. There might be a jumper on the board that you have to mingle in order to enable that setting.
Sep 21, 2008 | Computers & Internet
P4 Pentium
The GA-8IE comes with the 845E chipset. The below link will provide a list of all the processors the board will support.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1320
It appears that the fastest it will support is the P4 Prescott, Northwood, or Extreme @ 3.4GHz (800MHz FSB).
Hope this is the information you were looking for.
MO
Jul 04, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Hi all just precautionary inquiry, thank you.
do not plug in that processor as it is not supported by that motherboard. You will need to upgrade your motherboard to one capaple of running a p4 prescott chip(pretty much any sckt 478 board that has 800fsb). More info on your current board http://www.intel.com/design/motherbd/mv/mv_proc.htm
Dec 25, 2006 | Intel D850MV Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
