Question about RCA HD52W59 HDTV Projection Television
Blue screen replace the fly-back. cannot change chennl or bring up menu
  • REEOS Dec 19, 2008
    checked all conection still no pic
  • RCA Master
  • 5,138 Answers
Go back recheck ribbon conections make sure they are in good.
Posted on Dec 19, 2008
Can you advise what I need to do to access my BIOS
hi Barry J Edwards try to clean the RAM/memory 1st or change it sames to me like a RAM/memory problem..
Sep 14, 2015 | Computers & Internet
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
I have lost all the chennls on super box can anyone help
Have heard they have changed the nagrivision, comes up saying no signal, every channel gone just blank screens now. have heard they will all be off by august.
Mar 09, 2010 | StarTech.com StarView SV211K 2-port KVM...
Fly back lines
the unit is stating an impending breakdown in the horizontal circuit.bring it to a tech to for further analysis.
May 20, 2009 | Hitachi 27FX49B 27" TV
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
What next?
Check your tubes look to see if any of projection fluid is leaking,or if any has leaked onto chassis,alot of these tvs also had problem with that, also recheck second ribbon connection make sure it is in good ,they had trouble with ribbons and the connector plugs.
Dec 19, 2008 | RCA HD52W59 HDTV Projection Television
Lg tv type PT-48A80T
a defective product , bring it back to the store and swap it for a good one
Nov 27, 2008 | LG 42LC2D 42 in. LCD HDTV
Blue Menu Screen is always there
Dear All
This problem is caused by keyboard switches which are bad quality they are easy to replace, so if you are able to work with solder you can finish replacement in 15min.
Good luck.
Aug 29, 2007 | Neovo E-17A (Black) 17" LCD Monitor
RCA HD52W59 HDTV Projection Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
