Question about Compaq Evo N800C: Evo N800c P4 M-1.7GHz, 512MB RAM, 30GB HDD, DVD/CDRW combo drive, 56K Modem, Network Card... (EVON800CEVON800CP4M1) PC Notebook
Frequent freezing of mouse,and unexpected shut down
My machine make me sick by frequent shut down ,freezing of mouse,at the start ,say first 15 minutes ,then it works normally,
    President:
  • 2,961 Answers
The mouse is freezing because, you have either too many programmes running at start up, conflicting drivers, slow start up anti virus programmes, or you may have a virus or trojan/spyware programme running in the background. The shut down could be a processor overheating problem, so check all your vents and fans for clogged up dust and ensure your pc is well ventillated.
Posted on Apr 01, 2007
My mouse pointer is frozen in the. Middle of the screen
Hello Anthony- do a cold boot on your computer; meaning turn off your computer through the normal shut down process. Wait a few minutes for RAM to clear completely. Start the computer..do you have the same problem? If so, you may have to update the mouse drivers. If you are using a wireless mouse, make sure you replaced the batteries in the mouse and that the mouse receiver is plugged in properly- maybe jostled loose somehow.
If you added new peripherals you may have an IRQ conflict.
Try booting up in safe mode, if the mouse works without freezing, try booting up - initializing one driver at a time to isolate the problem by process of illumination.
Feb 12, 2017 | The Computers & Internet
After running about 15 minutes the engine dies out and won't start? what about 1/2 hr and able to restart but will die after cutting 15-20 minutes
Is it possible that your engine is overheating? When that happens, the engine tolerances expand, internal resistance increases and often the engine will just shut down till it cools, shrinks back to normal and then will restart. Check for oil levels and lubrication.
If it is that you better take care of asap before the engine permanently "freezes."
Sep 14, 2015 | Garden
Overheating "studio xps 7100"
Download this: http://almico.com/speedfan451.exe
It will tell you what is overheating. It may be the heatsink grease on the processor is dried out and not conducting heat away like it is supposed to.
Apr 14, 2014 | Dell Studio Xps 7100 PC Desktop
89 cougar 3'.8 car stalls. no spark. starts again after 10 to 20 minutes
It sounds like your crank sensor or cam sensor are failing. When either of those two sensors overheat they will shut down the engine until they cool down
Dec 09, 2012 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Hello, I have just bought my Bavaria 36 in the netherlands. We have sailed her to Sweden a few days ago. The boat is equipped with a chartplotter RayMarine RC 435. During our trip we noticed the folowing:...
One thing you might check is for any corrosion in the 12VDC power cable at any point on the way to the unit. If the wires are somewhat corroded they will heat up as the unit draws power and the inherent voltage drop a from heated wires may lower the available voltage to the unit so it shuts down.
Jun 20, 2011 | Raymarine Rc435 Chartplotter
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using...
Make sure the cooling fan for the laptop is not obstructed in any way or is not dirty. It's pretty common for a laptop to get plugged with dirt from normal use. Get a can of air and blow the machine out to remove dirt, lint or debris.
You could also have a defective battery, but try cleaning the machine first.
Feb 24, 2011 | Computers & Internet
Hitachi 50UX22B projection ultravision. shutting off on its own.
Since the set seems to recover somewhat, Id look for poor sonnections first rather than defective components. If you can solder and arecomfortable working inside the set, you may be able to fix this yourself. Are there any other symptoms other than just shutting down? For example, blinking standby lights?
Dan
Jan 12, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Mar 15, 2008 | Acer Aspire 1642ZWLMi Notebook
Dell Dimension 2400 Freezes frequently
check inside the case of the computer to make sure that the interface cable between the hard drive and the motherboard are fully connected. Also check to see if the RAM modules are fully inserted into their slots. If not, they try removing them one by one, until the computer starts up faster. If this doesn't fix it, then try a new hard drive, and interface cable.
Feb 21, 2008 | Dell Dimension 2400 PC Desktop
Computer freezes, No Keyboard No mouse, but machine keeps on running
Try to check the capacitors of the motherboard, maybe some of them are damage, they can cause this kind of problem
Nov 20, 2007 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Computers & Internet Logo
170 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
