Question about Swintec 7040 Typewriter
Constant beeping Swintec 2600 the constantly beeps when turned on. We have unpluged, turned off & on etc whith no results, There may have been a power outage or spike overnight. Thanks for the help.
  • Anonymous Mar 19, 2014
    Swintec 2416DM 128k no longer keeps files in memory. On power cycle is beeps 3 times. If I cycle it while beeping, it will beep once (normal) and I can use it, but nothing is kept in memory past a power cycle.
  • 215 Answers
Sounds like your selection sensor has got a wire broken. if you look at the wire bundle coming off of carrier, three of those are for selection sensor. 1 blue, 1 red, and 1 black. one of those are most likely broke from continuous movement of carrier back and forth. common problem on this machine. that repair would have to be done by a tech however, as it is not easy.
hth,
razors
Posted on Jan 12, 2009
    Scholar:
  • 183 Answers
SOUNDS LIKE THE MAIN BOARD OR POWER SUPPLY HAS GONE BAD. A POWER SURGE WOULD DO THAT OR IT COULD BE OLD AGE TAKE TO A REPAIR SHOP TO BE SURE
Posted on Dec 20, 2008
Krups coffee maker constantly beeping, even when no water or not turned on, when making coffee it beeps turns off then beeps and turns on - getting to the point of just unplugging to stop beeping.
Hello Linda Foster,
If there is NOT an OWNERS MANUAL immediately
available.. there are a huge selection of KRUPPS
machines...
Chose from the attached list...
Find the trouble section... Read & heed
Results for krupps coffee maker var myCallback function document ready...
Hope this helps...
(or REPOST with model number for BETTER QUALITY answers).
Carnac the Magnificent
Oct 25, 2017 | Krups Coffee Makers & Espresso Machines
During typing, daisywheel spontaneously readjusts itself and then the machine beeps and will not continue. Will it be expensive to fix? Ballpark cost?
Daisy wheel is kind of old school nowadays, you might have to go to a office supply store like staples etc, to possibly get it fixed
Feb 11, 2015 | Swintec 2600 Typewriter
Constant beeping on IBM-412CD phone after power outage
If you have more than one phone, phones 2-n need to be assigned different codes from the first ... Since the default phone code is '11', assign them with '12', '13', etc. via 1012, 1013, etc.
Feb 14, 2014 | IBM Corded Phone IBM412CID
Cpu beeps constantly then when i unplug the
Remove ur RAM and put it in another slot.
Jan 24, 2010 | Computers & Internet
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
Constant beep when power up
Continuous Beep = No Power, Loose Card, or Short.make sure all the cards are inserted correctly and also check your memory, make sure it is in the dimm slots properly
Nov 15, 2008 | Sony VAIO Digital Studio PCV-RX860...
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
Constant beeping and will not re-boot
Question- the beeping, is it short (1 second beeps) or long (2 or more seconds) and how many before it stops? or doesn't it? does it have any rhythm? The beeps correlate to some hardware problem, if you want to check the beeps yourself, just google "Bios beeps" and it will bring up a table of what the beeps mean.
J
Jan 07, 2008 | Computers & Internet
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Swintec 7040 Typewriter Logo
467 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
