Question about Maytag MLI7500A Iron
HOW DO I DESCALE A STEAM GENERATOR IRON
I CAN'T SEEM TO FIND THE IBSTRUCTIONS ANYWHERE, I HAVE A KENWOOD I THINK IT'S MODEL: kbs-11
i'm desperate to get it descaled as i;ve got bits coming through the soleplate
  • bovario
    bovario Feb 03, 2012
    You can add descaling solution to water tank, set low temperature to have water flow through iron for wfew seconds then repeat this again and again.
    Water with descaler solution will flush everything away.
    For spares can vesit my website www.bargains-zone.co.uk
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Posted on Sep 15, 2009
Can i get instruction manual for kenwood g1125STE, red light is flashing can you tell me why?
Posted on Nov 29, 2009
  • 7 Answers
Do a search for "Clean water deposits iron" and you'll come across the a listing that speaks about using vinegar and water to descale the iron.
Posted on Dec 22, 2008
    New Friend:
My problem with ken wood model kbs11 b is how to operate the steam when ironing
Posted on Mar 14, 2013
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
My kenwood kbs 11b is not producing steam and stand by light is flashing, what should i do?
the steam holes is plug.
If you have hard water doposit in the line try some cr7
Oct 30, 2010 | Euro-Pro Steam Generator EP8001 Iron
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Maytag MLI7500A Iron Logo
6,811 people viewed this question
Top Maytag Irons Experts
Marvin
Marvin
Are you a Maytag Iron Expert? Answer questions, earn points and help others
