Hohner hhb5t everything turns on tubes get hot but i get very little sound.
I have the 64 Chromatic octaves Professional Model by M Hohner. The slide is stuck. How can I fix it.
Try lubing with a little CRC 226 which is available at Home Depot in the electrical dept in a blue can. Use only this product as there are othe CRC products there. Tis is a water displacer and a very thin lubricant. Put some on the slide and work it gently. When you get it free, keep it free with just a tiny bit of the 226 once in a while.
Feb 13, 2011 | Hohner Super Chromonica Chromatic...
Where is the serial number on a hohner corona ii accordion?
Try asking by email at this link:http://www.hohner.eu/index.php5?2405 Also have a look at this article at this link:http://www.ehow.com/how_5998550_model-hohner-accordion Hope this helped.
Oct 24, 2010 | Hohner Corona II Diatonic Accordion
No water coming from hot valve on faucets
Have you thought about possible calcium buildup in your hot water tank/pipes? I am helping a friend in Palm Springs CA (California not Canada) and we are going to pour a really huge pile of vinegar into the hot water tank (let it sit for a day) then open up the hot water taps to the kitchen (where we don't have hot water flowing very well), then going to let everything sit for another day. Remove the aerator from the kitchen faucet after letting the vinegar/water solution sit in the pipes for a day, and turn on the kitchen hot water tap. Once all the **** is drained out, you must of course drain out the vinegar/water solution from your hot water tank or you will smell like French Fries (in Canada we put vinegar on French Fries) when you shower for a few days.
If you don't understand what the basic chemistry of dissolving calcium via this method is all about, then please call a professional plumber. Hope this helps, and remember that Google is your friend (sometimes), but be careful...
Apr 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hohner symphonie D98, no key board sound
Look for an exploded electrolytic capacitor. They amke a pretty loud bang and make a visible mess. CLEAN any residue when restoring.
Dec 31, 2009 | Hohner Music
Problem with second and third holes in chromonica 270
You might find the info you need here:http://www.harmonicalessons.com/repairs_chart.html It sounds to me as if you have some stuck reeds.
Oct 17, 2009 | Hohner Super Chromonica Chromatic...
Hohner 12 hole Chromatic, Super Chromonica. A # is " flat."
You can take it apart by removing the two screws, see if any of the reels seem blocked or obstructed by dirt, bits of dust, oxydation (greenish crystalline stuff) or similar, try to remove the stuff that seems to obstruct the reel with a medium hardness paintbrush (you might want to use some alcohol), but be very careful not to permanently bend or otherwise damage the reels, it will ruin the sound of the harmonica.
regards
Triarcuate
Oct 01, 2009 | Hohner Super Chromonica Chromatic...
Have a hohner button accordian think it got bit of age to it how can i date it and find out what model it is it has no details on it wotsoever pls help
Try www.hohnerusa.com or www.accordion-search.com under new sites. Hohners toll free number is 800-446-6010. Good Luck.
May 15, 2009 | Hohner Corona II Diatonic Accordion
Ice maker stopped working
I have the same problem with my whirlpool every once in a while, and I found out that if I run a hot air dryer at the back of the fridge where the water tube comes in and along the ice maker it loosens everything up. I think that for some reason the water freezes in the tube somehow and prevents a full cycle. When I am using the hair dryer i can feel the frozen ice come sliding out of the tube. Also I know when I am getting close to thawing everything out when the ice maker runs through a cycle while I am blowing the hot air on it. Good luck.
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
73 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
