Question about Microsoft Wireless Network Adapter
Network adapters device drivers not installed
    Problem Solver:
  • 10 Answers
The network adapters dont even show up in the device manager, where can i download the drivers?
  1. If the network adapter isn't showing up in the Device Manager, even as an Unknown Device, then the Network adapter may be faulty.
  2. Try removing the Network adapter, restart the computer, then shut down the computer after the restart.
  3. Now reinstall the adapter with the computer off.
  4. Once the Network card is reinstalled, turn the computer on. Check the Device Manager for your Network Adapter.
  5. The computer should detect the card and ask you for drivers. If it doesn't, that means it either automatically found the drivers and installed them, or your network adapter has died.
Feb 15, 2011 | Computers & Internet
I HAVE LOST MY INSTALLATION CD
The installation CD contains a driver of the adapter to run the device.If you lost the CD, you can let your computer find the driver online.
Connect your computer to the internet .Plug the USB device to your laptop. Go to device manager , look under network adapter , find Compact Wireless-G USB Network Adapter w/ SpeedBooster, right-click it, hit update driver, there will be a windows update pop-up page, so just hit search automatically.
Nov 08, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
My network with onborad not wok , why ?
Try to check the network device in your device manager if they are installed in your computer. Just right click the My Computer then click properties. System Properties dialogue box appears click Hardware then click Device Manager. Device Manager dialogue box appears, check if the Network Adapter of your device manager have no problem. Note: If the device have a mark like this, ? or ! it means the device have a problem. If they have a mark like that, you need to install the driver of your Network Adapter to work it normally. Just right click the Network Adapter device then click Update Driver. After that, insert your cd driver in the cd-rom then click Next button and follow the instruction on the screen to finish installing that driver. But it the device has no any mark like this; ? or ! the device have no problem.
Jun 05, 2010 | ASUS P5PE-VM Motherboard
My gateway profile 5 will not install the network driver. 1394 net adapter is installed but doesn't connect me to the internet.
1394 is NOT your Network adapter... you need to go to device manager and look there for any "Network Adapter" then right click and "Update Drivers". Your network card will have a "Name" or say PCI network device or the like. Thats the driver you need to find and install. Hopefully it is on your drive somewhere.
Jan 31, 2010 | Gateway Profile 5 PC Desktop
Network adapter not working
your network adapter driver is not installed. Install it and then have a look . open device manager and in that look for network adapters if u can see there then ur driver is installed successfully..
Aug 26, 2009 | Compaq Network adapter
Broadcom network adapter has code 10
Try to update its drivers. Go to the Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
How to go to Device Manager:
1. Right-click on My Computer on the desktop and then click on Properties. Then click on the Hardware tab and then Device Manager button.
2. Double-click on Network Adapter. Double-click on your network adapter to view its properties.
3. Look for the Device Status or any error message. If it says "This device is working properly" then the adapter is properly installed.
Jul 17, 2009 | Broadcom BCM5721 NetXtreme Ethernet...
Network adapters vanished
Try removing the network adapter and reinserting it.
Jun 11, 2009 | Toshiba PA3235U-3BTM Network Adapter
Yellow exclamation mark over the network adapter- 6To4 adapter. When I uninstalled and restarted my computer the adapter was not reinstalled. Sony laptop with Vista 32 OS.
the yellow exclamation mark indicates that the driver is not installed... run the installation disk once again install the adapter .. if unable to install with cd then, right click on the adapter from device manager and click update driver and manually update the driver ... it should work
Apr 16, 2009 | Packard Bell 1580509280 Network Adapter
Compaq presario broadcom adapter not showing
Hi!
I will assume that your broadcom adapter is not showing up under Device Manager > Network Adapters. It will happen if the driver is not properly installed.
Look for "Other Devices" under Device Manager. Usually, it will show as Network Controller or Ethernet Controller. Right click that and select update driver. Make sure that you have the driver or file for that adapter. Once the driver is properly installed, it will be under Network Adapter with the correct name.
I hope that helps.
Good luck and have a nice day!
Nov 27, 2008 | HP Computers & Internet
Wifi connectivity problem
It's possible that the driver for your wireless adapter is already installed. Check under Device Manager > Network Adapters if there is anything pertaining to your wireless adapter. Make sure that your wireless adapter (under Device manager > Network adapters) does not have any red X or yellow question mark.
Red X indicated that it's disabled , while yellow question mark will suggest that you need to update the driver. If your wireless adapter is working properly under Device Manager > Network adapters then you will need to configure it's utility for wireless connection.
If you are running windows XP, look for the wireless icon in the lower right side of your task bar and use it to connect to your preferred network.
Sep 30, 2008 | Computers & Internet
Microsoft Wireless Network Adapter Logo
76 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
