Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Power braker strip
Any time I connet my refrigerator to the power, my braker strip, any particular reazon for this problem?
  • 750 Answers
Hello
Welcome
The fridge is not a computer and should not be plugged into a gif or surge breaker. Plug it into and outlet!
Can not do this.
Please remember to leave a solved rating before you leave our site.
Thank you
Posted on Dec 19, 2008
Active Smart Control Fridge Freezer E402B.Has just shut down.Going fine than it just shut down.No power.No lights,No compressor,No fans?????The power outlet that provided power to fridge seemed very h
first check the braker in the electrical panel for that line. the braker with the problem will be in the mid posison. reset it by pulling allway back and then all the way on...
Mar 30, 2014 | Refrigerators
Hi There While this mshine was washing we had a electric braker activated (could be because of the mashine?)Then I flick the braker and all went to the end but it doasn't open the door , we try to do...
Unplug the unit from the power and leave for about 2 hours Then try the door. Cycle interruption can cause the door to remain locked. Check what other items are on the same circuit. Jugs kettles tv frypans etc. Have an electrician divide the circuit to reduce the amperage load on that particular circuit to save repeats of this event.
Please rate my help++++Thanks for using FIXYA
Aug 01, 2010 | Bosch Washing Machines
Fridge wont get cold
Check your brakers, on your house braker panel, it should be a 20 amp, pust it all the way off, then all the way on to reset
Jul 04, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Installed used fridge and no power
make sure your circuit braker is on
Apr 25, 2010 | Dometic RM2852 Refrigerator
The dry will not get hot the knob had sparks that came from it
there are many different things that could lead to no heat condition,first check the input power terminal strip where the power cord enters and make sure the leads arnt burnt off,then the hi-limit switch found on the heating element case can be bad,an open heating element, a bias thermostat in some machines,you will need to open up the machine to check most of these parts except the power input with a multi-meter
Jan 12, 2010 | Speed Queen AES28AWF Electric Dryer
To convert the mains to 12volt supply to 12Volt suppl only
Well, the connector u can buy frm the particular company shop!! but for supply reazon, u hv to desgin plug for particular given vols..or just buy the normal adaptor or variable adopter
and get connect he 4 pin plug on that and enjoy!!
Nov 10, 2009 | Cars & Trucks
My wii does not turn on and all connetions are plugged in
Make sure power connection firmly in both ends.
Change power outlet... if plugging in to strip TEST directly to wall outlet.
Try differenct wall outlet.
Try different WII power adapter.
Jul 28, 2009 | Nintendo Wii Console
BRAKER STRIP
i am guessing you mean you are using a 6 outlet breaker strip. you should not do that as they cant handle the starting of the refr. compressor. do not use any extension cords either, but if you must just get a "heavy" enough one that can handle 20 amps of load.
also make sure you are not using any outlet that has a "gfci" these are not for use with appliances and should only be used when the outlet is close to a water source.
Dec 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
