Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
BRAKER STRIP Any time I connet the refrigerator to the power, my braker strip for some reazon I check all the cables one by one and I don't see any damage on it.
  • 318 Answers
I am guessing you mean you are using a 6 outlet breaker strip. you should not do that as they cant handle the starting of the refr. compressor. do not use any extension cords either, but if you must just get a "heavy" enough one that can handle 20 amps of load.
also make sure you are not using any outlet that has a "gfci" these are not for use with appliances and should only be used when the outlet is close to a water source.
Posted on Dec 28, 2008
Why does the washing machine keep turning off all the power to my home
It is drawing to much load for the circuit braker . check the power the machine uses, ( on the plate on the machine) then check the power rating on the circuit braker, if it is rated above the power of the washing machine there is to much load on that circuit. and another cable will have to be run for the machine.
Sep 28, 2014 | Washing Machines
How do i fix my proseries water pump
unplugging it while it was runnong shouldn't damage it, probably just the circuit braker. check to see if there is a button or some type of circuit braker on the unit and reset it, if it does not have one check the circuit braker that supplies it power. (in your braker box)
Jun 23, 2014 | Pool & Spa
Active Smart Control Fridge Freezer E402B.Has just shut down.Going fine than it just shut down.No power.No lights,No compressor,No fans?????The power outlet that provided power to fridge seemed very h
first check the braker in the electrical panel for that line. the braker with the problem will be in the mid posison. reset it by pulling allway back and then all the way on...
Mar 30, 2014 | Refrigerators
Fridge wont get cold
Check your brakers, on your house braker panel, it should be a 20 amp, pust it all the way off, then all the way on to reset
Jul 04, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
The dry will not get hot the knob had sparks that came from it
there are many different things that could lead to no heat condition,first check the input power terminal strip where the power cord enters and make sure the leads arnt burnt off,then the hi-limit switch found on the heating element case can be bad,an open heating element, a bias thermostat in some machines,you will need to open up the machine to check most of these parts except the power input with a multi-meter
Jan 12, 2010 | Speed Queen AES28AWF Electric Dryer
No power on kenmore range
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If everything above is ok, move on to the power cord junction point. make sure the power cord has not separated from the junction point on the backside of the unit.
Jul 16, 2009 | Kitchen Ranges
2000 Blazer. No power to the orange wire for either front seat. Which fuse or relay controls the frt power seats? Its not listed on the fuse box covers and I do not have an owners manual.
The orange wire is the power wire for both seats.It gets its power from the power seat circuit braker (20 amp) located at the body relay block.It is located behind left side of dash near fuse block. Remove circuit braker and check for power in body relay cavity that you pulled the relay out of if power is on one side change circuit braker and if no power on either side then you have a bad main fuse near battery or under hood in main fuse block. Joe ASE Master Tech
Mar 05, 2009 | 2000 Chevrolet Blazer
Power braker strip
Hello
Welcome
The fridge is not a computer and should not be plugged into a gif or surge breaker. Plug it into and outlet!
Can not do this.
Please remember to leave a solved rating before you leave our site.
Thank you
Dec 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Problem with my dryer
unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
Mar 24, 2007 | Whirlpool LER2614JQ Electric Dryer
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
rlrguitar
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
