Question about Philips 42PF5521D 42 in. HD-Ready Plasma Television
42 plasma philips
Tv will not turn on,sound comes on then tv clicks still no picture,control pannel [manual] does not respond. I have the same problem - I hit the power button on my remote - the green light on the TV shows it is coming on - I hear the TV click a couple times, no picture, no sounds. After 3 attempts it usually finally works. I had contacted Philips before and they sent out a repair comapny that took my TV away, fixed something that had to do with the power converter or something - but the TV is still the same - I have never pressed the power button and had it turn on at first attempt.
HELP!!
I had a similar problem. You likely have 1 or more bad capacitors on the power supply board. You can easily identify them - they have a raised or rounded appearance on the top instead of being flat. Remove the power supply board and take to electronics repair shop and have them replaced. The capacitors only cost me $4.24 for two. Now mine works fine. The repair man replaced them for free. It took him only 10 minutes to solder them on the board. Easy, cheap fix but manufacturer won't tell you that. I fixed this on 1-02-09. My 2 bad capacitors were "3300uf 10v" and I replaced with "3300uf 16v" but you might be able to replace with "4700uf 35 v" also.
Posted on Jan 03, 2009
  • Philips Master
  • 19,396 Answers
All you can do at home is leaving the TV unplugged for one or two hours and see if this solve the problem.
If the unit has just been repaired, and it is faulty again, contact the service back and have the problem fixed.
Common faults on plasma TV can concert the PSU power supply board, the sustain boards, and other boards, wiring and connectors.
The testing and repair job must eb done by a technician.
Posted on Dec 19, 2008
42 inch plasma tv
Power supply needs repair.Est in range of $150 is fair. Find a qualified shop
May 12, 2010 | Philips 42PF9631D 42 in. Plasma Television
No picture in Philips 42pf7220a/37 Plasma TV.
Hi my name is Roety,
I can help you with your issue ,
You can look for two bad capacitors on the power supply. They will look swollen on top like this photo
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Nov 14, 2009 | Philips 42PF7220A 42 in. Plasma Television
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Philips 30" Plasma Flat screen
if you are getting sound but no picture that good at least the set is not
going into protection mode. Which can make fault finding more
difficult.
What you should check is that the 12 volt supply from the power supply
to the signal board is present.
other then that check that you have the high voltages present if this is not
the case then you most probably have an issue with the x control board
or scavio as its known.
Oct 27, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42 plasma philips
When you turn on the set and it has sound, can you bring up the menue? tonyfalcione@msn.com.
Oct 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
489 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
