Question about Bose Companion III Computer Speakers
Creative Inspire 5300 Volume Control broken!
The pin connector (the part that plugs into the subwoofer) on the end of the wire for the wired remote has broken off, and I don't know which color wire goes to which pin!
Can someone find out for me... maybe open it up somehow and look or some wiring schematic or other...
Thanks in advance!!
  • PeteBevan Mar 04, 2009
    I have lost the lead totaly anyone know the connections?
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Posted on Jul 27, 2012
  • 3 more comments
  • Federico Sep 11, 2012
    Hi, thanks for this diagram, but is there a way to use this speaker system without remote? Lost mine long time ago and I'm trying to recycle a bit. :)
  • Cekins Jan 07, 2013
    The system uses voltage controlled amplifiers for both volume and balance, so the only problem to use without remote is balance which needs 5 volts to be centered (if I remember correctly it uses 10 volts for the pots), so a solution is two 5k resistors tied to Vdd and GND and the center tied to balance input. For volume - 10 volts can directly be connected. Of course it will be on max volume. "Power on" should be tied to GND to run internal power supplies. Actually I bought my speakers without power supply and remote for 20Euro without knowing that they need remote. Then I opened the box and found how it works :)
  • Fadhel Chemmem
    Fadhel Chemmem Mar 09, 2014
    can you post a real diagram of the control circuit plz ?
  • Cekins Apr 26, 2014
    I haven't seen the actual remote - I bought mine from the scrap. Then I realized that it cannot be even turned on without it. After few hours of investigating the circuit, found how to make my one remote.
    New Friend:
For those searching the answer "How to replace/repair Creative Inspire 5.1 5200 volume control":
Posted on Dec 19, 2012
  • 3 Answers
SOLUTION: Dudes, Had the same issue, got an old PS2 mouse (same plug), cut off the plug, fiddled with different combinations. Joining 2 wires turns it on, another 2 puts the volumn to full...
JasonxartCreative Inspire 5300 Volume Control broken! - 10_4_2012_3_37_53_pm.jpg
Posted on Oct 04, 2012
  • 2 more comments
  • Bryan Li
    Bryan Li Jan 14, 2014
    Doing this (shorting power to ground, and the Vcc to Volume) will work for only front speakers at full volume. You will need to use a 'pot' (potentiometer; a.k.a. variable resistor) to set balance or use a couple of resistors to create a voltage division. This should not be very hard to do, except you will need a minimum of 3 resistors; not 2 like the other posts suggest)
  • Taybur Rahaman Shamim
    Taybur Rahaman Shamim Mar 13, 2014
    its that work my inspire m5300 ?????
  • Fadhel Chemmem
    Fadhel Chemmem Mar 15, 2014
    is this corrent ?http://i49.photobucket.com/albums/f269/t...
  • Fadhel Chemmem
    with : blue=led, green=balance mid pot, red=ground,white=Vref, Yellow volume mid pot; Black=switch on
5 Suggested Answers
SOURCE: remote volume control needed for Creative Inspire 4.1 4400
Dear sir
I brought sound system, but unfortunately I miss place volume control, I would like to ask suggestion without volume control could i operate sound system....... could i get seprate part to buy from delers or mfg.
please advice.
Thanks
maheshrn2002@yahoo.com
Posted on May 02, 2010
Open SKy
  • 620 Answers
SOURCE: Creative Gigaworks S750 9 pin color code
Cliff
First things first:
This is not a special and critical eq. from creative, you can take it to the reapair shop and they sometimes have the schematics, other than this, sorry you have to RMS to CREATIVE.
Carl
Posted on Feb 01, 2008
  • 76 Answers
SOURCE: Volume control for Inspire 5300
this s bcoz of loose connection...jus press the volume control with ful force once then it will be solved...chill!!!!
Posted on Aug 09, 2009
  • 71 Answers
SOURCE: Sound through right speaker is not proper Creative Inspire M2600
This sounds like an electrical problem in the speaker circuitry - between the speaker(s) and the control knob.
Posted on Jun 02, 2009
Creative volume contoller pin damaged 4.1 inspire
My sound system for creative 4.1 speaker volume control pin spoyel so how I use without volume control
Feb 07, 2013 | Creative Labs Inspire 4400 Computer...
I Have a t7700 Creative speaker sytem that have a broken wired remote, i want to bypass him and use the speaker system without a remote(mkae him turn on only on max volume if necessary). how do i do i
Try this (I hope your system is just stereo.) Buy a jack to fit the headphone plugin. The plug that into the speaker input. That should reroute the sound to the speakers.
May 26, 2012 | Creative Labs Inspire T7700 Computer...
I want to buy a creative inspire m 5300 wired remote volume control
Jasonxart
Feb 05, 2012 | Audio Players & Recorders
Creative inspire 4.1 volume control got wet
sir i want creative 4.1 volume control wire please
pavanpralhad@gmail.com
Sep 30, 2009 | Creative Labs Inspire 4400 Computer...
Aug 09, 2009 | Creative Labs Inspire 5300 Computer...
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
Broken Volume Control
try ebay or bizrate
it may be easier than you think to fix it.
look for a new cable or a similar end piece and you can splice the new cable onto the old one.
if you would like when you get a new cable i can assist you step by step to fix it.. you will need to get electical tape and wire cutters/strippers
Apr 26, 2009 | Creative Labs Inspire T3030 Computer...
Creative Inspire 5.1 5200 Remote Wiring
Hi glopher
pin 1 (starting from far left when LED is facing up) = green
pin 2 = light blue/lime blue
pin 3 = black
pin 4 = yellow
pin 5 = pink
pin 6 = red
pin 7 = violet
pin 8 (far right) = blue
I hope this helps
Open345
May 18, 2008 | Audio Players & Recorders
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Bose Companion  III Computer Speakers Logo
13,491 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
