Dual 1228 turntable platter not spinning, the motor will not turn
How can I get my dual model 1228 turntable paltter to spin, it will not, the motor is not spinning, but I can tell it is on?. It could be lubricating issue, or is it something like a motor starter, if it as one?. Please let me know. Thank you.
  • rickanthony Dec 20, 2008
    Hi Dan, (abrsvcs), Thank you for the information. I have done this, the idler wheel is fine and the motor itself is not turning, yet I think power is getting to the motor. Could it be a motor starter componet?. Thanks. Mike.
    Problem Solver:
  • 6 Answers
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
Have a 1212 with the similar problem, there are 2 bearings that should be lubricated on the top and bottom of the motor, also your idler wheel may be glazed or dirty. Get a simple emery board ( nail file) use the fine side, clean up all filings, then clean with rubbing alcohol, or rubber wheel cleaner. Be sure not to touch surfaces, also clean platter where idler touches. I did mine while it was running to avoid getting flat spots on the idler. I was surprised, it worked!. email me if you have any other problems, am going to rebuild a 1228 today (jfinpa@dejazzd.com)
Posted on Mar 22, 2009
  • 4,234 Answers
This particular unit uses an idler wheel to drive the table. Remove the platter and check the rubber wheel. It may be dirty, or just dry and slick. This part may need to be replaced or treated.
Dan
Posted on Dec 19, 2008
  • ABRsvcs Dec 22, 2008
    There is no "starter" involved. It is possible that the motor has seized a bit. All you can do is to try and rebuild the motor. I don't believe that replacements are available any more. Try lubricating the motor and/or spinning it by hand. It should turn freely.
    Keep us posted.
    Dan
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Platter not spinning
Is this a belt driven model? If so then just replace the belt. Also check that platter can turn. Sometimes grease or dirt builds up. If you can't turn it by hand then neither can the motor.
Feb 16, 2013 | Audio Players & Recorders
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
If you can turn the platter easily by hand, then so should the motor. You can also disconect the power leads to the motor and hook up a PP9 9 volt battery to it. If it\'s slow and easily stopped from rotating then there\'s nothing wrong with the power to the motor and the motor is bad!
Dec 31, 2012 | Audio Players & Recorders
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Feb 15, 2010 | Sony PS-LX250H Turntable
I HAVE A 1951 AMI D-80 JUKEBOX,THE TURNTABLE IS JAMMED.
There are two motors with beige/tan plastic covers over them, one on turn table platter and the other on the record changer mechanism table. Take the cover off the one on the turntable and spin the motor by hand. Depending on how you spin it the arm will either go back up or down
Jan 03, 2010 | Audio Players & Recorders
My turn tabel isnt spinning
The drive belt has come off. Open the lid. Remove the rubber mat on the platter. Remove the C-shaped clip from the center of the turntable. Lift the platter up and off. Find the flat rubber band that connects platter and the motor. Plug it in and verify that the motor turns when you press power, then standby, then phono.If the motor spins, unplug power and place the drive belt on the underside of the platter. This is not easy, but it can be done with patience. Then put the C-clip back on and replace the mat. Congrats!.
Oct 10, 2009 | Philco 841205 Turntable
The belt fell of the gears on my turntable.
Hi dont know the model but normally like so:
Take the platter of the turntable, it should just lift of, but there could be a circlip in the middle that needs to come off first. Just lift the mat first.
Place the belt back onto the platter first, should see where it goes, then put the platter back on. There are holes in the paltter which you can then grab the belt and pull it over the motor spindle.
Hope that helps
Jul 27, 2009 | Sony PS-LX250H Turntable
JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Jun 20, 2009 | JVC Audio Players & Recorders
Garrard turntable model 630s
There are a couple of things that need to be done here and there is no guarantee that the unit will work, but I have been successful in the past.
First remove the platter and clean all of the grease out of the unit. With all of hte grease removed, replace the platter and make sure that it turns freely. Regrease the unit one all of the old is removed. Next you will need to clean and treat the rubber drive wheel.
Good luck,
DAn
Mar 21, 2009 | Teac AG-V1050 Receiver
1,383 people viewed this question
 Grubhead
Grubhead
