Question about Sharp 21" Multi System Stereo TV
I need an unlocking code for a Sharp DVD player DV-SL10X
My Sharp dvd player is only capable of playing Region 4 dvd's. I need it to play a Region 1 dvd. Does anyone have a code that will unlock my dvd and make it region free?
  • JTC13
    JTC13 May 11, 2010
    Please post model number of your DVD player.
jaffa012001
  • 376 Answers
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Posted on Oct 19, 2008
drlalitv
  • 488 Answers
SOURCE: REGION FREE CODES
try this:
1. Power
2. open
3. stop
4. applay code : 734466
5. select region 0
6. exit setup
hope it helps!
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Posted on Dec 12, 2008
jaffa012001
  • 376 Answers
SOURCE: Unlock Sharp DVD region code
open drawer on dvd
then press volume + key
while holding it down press the language key
and release volume+ still holding language
then look then use up and down arrow keys to change region code
Posted on Dec 15, 2008
SOURCE: Region unlocking for a Sharp DV-NC80
I would like to play Area 1 DVDs on our Sharp DV-SL 1200 DVD player - please help us unlock it - Many Thanks
Posted on Dec 29, 2010
Hello my sharp dv-nc200 dvd player can only play regional code 4, but I have dvd's from europe, which are regional code 2, can I change this somwhere in the setup or menu or elsewhere thanks a lot for...
If it is set to only play region 4 discs, then that's what the player can do - you cannot change the region code and I don't believe there is a hack to unlock this particular model to make it region-free.
The only types of discs acceptable are those which match the region of the player or discs which are 0 (region-free). I have never found a menu option to change region settings in any player. It is not modifiable nor accessible. There may be a player on the market which is multi-region compatible and will play your region 2 DVDs perfectly; just not this one. It is a restriction, not a fault.
Do not fix what isn't broken.
Feb 01, 2011 | Sharp DV-NC200
Tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 | Televison & Video
How do I set the player to multi region for a Sharp DV-SL1500W ?
try this
- switch on DVD player
- press eject (tray open)
- press stop
- press 734466
select 0 on OSD for region free
Mar 18, 2009 | Sharp DV-SL1500W DVD Player
How do I set the player to multi region?
try this code
- press stop
- press 734466
REGION FREE CODES
try this:
1. Power
2. open
3. stop
5. select region 0
6. exit setup
hope it helps!
Nov 21, 2008 | Televison & Video
Unlocking DVD - Pioneer DV400 k
Hi Jetix,
If the DVD player is capable of playing other regions, you should be able to change the region setting through the menu section. If there isn't an option to change the region settings in the menu, then your DVD player is not able to play other DVDs from other regions.
Sincerely,
Agent Xiong
May 27, 2008 | Televison & Video
Unlocking Region Codes for NEC NDT 44A
TO UNLOCK NEC NDT-44A
1. Press EJECT
2. Enter 0, 0, 0
3. Enter the region you want (0 = multi-region)
4. Press PAUSE
(I feel like I just won the lottery!)
May 16, 2008 | Televison & Video
UNLOCKING CODES
That Is The Same Code I Have It Should Work Make Sure Its All Being Entered From The Factory Remote.
Apr 12, 2008 | Sharp DV-SL1500W DVD Player
Apr 10, 2008 | Sharp DV-NC80 DVD Player/VCR
Region codes
Try here...........
http://www.dvd.reviewer.co.uk/info/multiregion/
There are 2 on page 79 but you have not said what model yours is, when you post always give the model number of your product.
or maybe here,
http://www.dvdhacks.co.uk/hacksearch/hacksearch.asp?player=SHARP&Sub=Find
Feb 18, 2008 | Sharp DV-NC80 DVD Player/VCR
Televison & Video Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
