Question about IBM ThinkPad T42 Notebook
No hard drive page in bios
I want to replace the Hard drive, but the PC does nort "see" the new one.
I have looked in Bios and cannot see any entries for the HDD.
Does this mean the Bios may be locked?
Do I have to use an identical replacement to the original?
  • john821 Dec 23, 2008
    This seems to be a problem in bios, it does not get as far as trying to boot!
    I will run the pc up and list anything it says to clarify.
    I am a bit busy at present due to redundancy, but will try to do ASAP.
    Sergeant:
  • 306 Answers
If the hard drive has not been formatted you will need to boot to the operating system cd. Each hard drive manufacturer has their own drive manager program which you can download and burn to cd on another computer as well. You do not need to have the same brand as the original. If you have any trouble with the formatting please tell me and I will help you. Steve Medley
Posted on Dec 19, 2008
  • Stephen Medley
    Stephen Medley Dec 23, 2008
    I am here as long as you need:) Steve
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
I recently replaced the motherboard, video card and hard drive in my dell d800. The hard drive is new, but when I try to boot-up the computer gives an error message that there is no hard drive detected....
If it says there is no hard drive detected, then the BIOS is looking for one.
When you place your system disk in the drive to load on a fresh system, if you are using Windows, it will automatically detect the pressence of a hard drive, initialize it and format it. If it doesn't, put the hard drive in a USB caddy and initialize it from another pc, then place it back in the notebook.
Hope that helps.
Nov 24, 2010 | Dell Latitude D800 Notebook
I replaced a bad hard drive for a new one, but is giving this error "error while initializing the NIC" I tried with another hard drive and it works fine. What it could be a bad hard drive?
This is an Bios error
Solution:
Reset your bios to default, save changes and reboot your machine it should do that magic that you are looking for.
Aug 10, 2010 | Acer Aspire One PC Notebook
When i start up my computer (Accer 4230) i get this message "UNDI PXE 2.0, Media test failure, check cable, exiting PXE ROM. The message repeats over and over and it wont start up. I don't have an...
Start the computer and hit the F2 key until you get into the BIOS. When in the BIOS you can see in the Main/general page whether the hard drive is seen by the system. You will see HDD (hard drive) CD-ROM which is the optical disk drive.
If you see the hard drive the look for boot options in the tabs. When you get to boot options set the HDD as the first boot device, save the settings and exit the BIOS.
Hopefully the laptop will restart and boot from the hard drive, thus into Windows.
If the hard drive is not seen in the BIOS then the hard drive has failed and needs replacing.
If you have a BIOS password then start the computer hit F12 repeatedly until you see the boot option menu and choose the HDD.
Regards.
Feb 09, 2010 | Acer TravelMate 4230-6499 Notebook
My computer cannot find new hard drive disk . my hdd is western 80 ide
Make sure that the IDE channel you are using is turned on in the BIOS. In the optipled line, you press either delete or F2 to enter the bios when the computer is first powered on. If you're adding a HDD, the bios must be set to look for the hard drive. If you're replacing the hard drive, let the BIOS recognize the drive - save the changes and then reboot.
Jan 22, 2010 | Dell OptiPlex GX260 PC Desktop
Laptop will not start,
looks as though your hard drive is u/s Try and see if it is visible in the bios pages, if not replace it. Bios being, when you switch on you press f2, or ctl-alt.del or just del key. This puts you into the BIOS which tells the computer what it can and cannot do. The 1st page should have your hard drive listed, if not then replace it.
Jan 05, 2010 | Advent Netbook
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
Realtek media test failed check cable pxe exiting flashing
As the computer starts hit F2 to get you into the bios, look for boot options and set the HDD (hard disk drive) to the first boot device, hit F10, save the changes and exit the bios. The computer will restart and should boot from the hard drive. If it doesn't go back into the bios and look to see if the drive is recognized in the main page of the bios.
If the hard drive is not there then there could be a chance that the hard drive has failed.
Please let me know how you get on and if you need any further assistance.
Good luck.
Aug 26, 2009 | Acer Aspire 5100-5022 Notebook
Turned on and is asking for bios password
If you have the hard drive installed in a desktop, remove your CMOS battery for about 5 minutes. Replace and you should be good to go. You will need to reset the time and date on your pc.
Good Luck
C2Solutions
Aug 19, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Toshiba m400 builtin hard is offline
Did you look at the BIOS setting? Try hitting Esc then F1
Jan 27, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
IBM ThinkPad T42 Notebook Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
