Question about Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum
My 2month old hoover bagless stopped working completely!
My hoover vacuum is only two months old and it stopped working completely! It won't turn on at all. what do I do? i've tried plugging it in several outlets in my home and it won't turn on!
  • 1 more comment
  • Stewartr002 Nov 12, 2007
    Won't turn on after heavy use. Acts like a power switch is broke. Less than 3 months old. Is there a reset or fuse to hit?
    Randy
  • Anonymous Dec 21, 2007
    The vacuum just stopped, dead, while I was vacuuming after about 20 minutes usage. Is there a reset button? It won't turn back on even after 30 minutes of being turned off. It is only a few months old and has been used infrequently.
  • Anonymous Mar 23, 2014
    the machine was plugged in and worded fine but turned off after a few moments and won't turn back on, it is only 1 month old
I found out there was a large dusty clog in my vacuum. I had to clean it out then leave it un-plugged for quite a long time.
There is an automatic shut-off on the vacuum so it doesn't over heat and it won't turn back on it you don't leave it un-plugged and cleaned out.
Posted on Apr 02, 2009
  • 97 Answers
In this case it will be the switch.
Posted on Jul 29, 2009
I may have figured out a way to make this thing work. If you find that the problem is the flimsy, floppy piece of plastic that I mentioned above, I think that the thing to do is figure out a way to make the narrow sticking out fin-like section that activates the switch wider. I think what happens is that fin slips over to one side or another and then does flip the switch. What I just did is cut a hard rubber washer into two half circles (or approximate half circles) and attached those on each side of that fin. So now I have a nice wide switch activator. I attached the pieces with exterior mounting tape. I imagine that some sort of adhesive could be used too, as long as it is not something that would dissolve the plastic.
Posted on Apr 08, 2007
It's a crappy design. Take the two long bolts off that hold the piece with the handle on. You will see the actual switch inside. The switch on the handle activates the real switch via a flimsy floppy piece of plastic. Ours sticks on...what a peice of junk!!!!!!!!!!!!!!!!!!1
Posted on Apr 07, 2007
    President:
  • 1,462 Answers
Check fuse of course it may be the mains lead fractured usually where it enters appliance or defective switch. to test, bypass switch, switch on and see if it goes. be careful - disconnect from mains
Posted on Mar 31, 2007
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
Only a month old and it won't turn on anymore
Check Hoover's site to see if your's is under there recall. There's a problem in the cord rewinder. Mine had same issue.
Dec 29, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Vacuum just stopped, won't turn on
Take it back under guarantee, could be faulty mains lead or switch or motor
Sep 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Hoover Bagless
if the belt is more than six months old then change it even if it is not broken. then replace your filters if that doesnt work than check the hoses for a clog drop a marble down them and make sure it comes out.
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum Logo
667 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
