Question about Epson Office Equipment & Supplies
Epson C1000 Photoconductor Reset Instructions
Can anyone please tell me how to replace the fuse & which type of fuse to put into the photoconductor unit, it printed well before the conter stopped the printer.
MAny thanks
  • tonygch96 Dec 27, 2008
    Many thanks for the help, problem now sorted
Hi it's simple
Take out the conductor, look for two metal strips about 8mm by 25mm they are at the bottem left or right, depents how you have the conductor infront of you.
The strips are about 5mm apart from each other.
Take the out gently as they are around the side and fixed with a plastic pin. Loosen them at the other end.
under these strips you find a 80ma fuse
An new lifetime for your cundoctor is set.
Frank
Posted on Dec 13, 2009
Thanks for the tip its a great solution, now i have a new photoconductor here in Mexico. Thanks a lot :)
Posted on May 22, 2011
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
It show 84 replace photoconductor
84 replace photoconductor on the display indicates that the photoconductor has reached its expected life rating. You may continue to print but will be at risk for developing print quality issues. It is recommended that photoconductor unit be replaced. After replacing a photoconductor unit, you will also need to manually reset the PC counter, Thanks
Sep 22, 2010 | Lexmark Lemark E352DN Laser Printer
Replace photoconductor message
I am looking into the reset chip which you can find in ebay.
The cost of the new chip is around $15 dollars
That will make the msg dissapear.
I do not want to buy a $200+ unit.... :(
Jun 02, 2010 | Epson ACULASER CX11NF All-In-One Printer
Photoconductor trouble
You will need to get the photoconductor unit replaced.
You can get detailed information about the same from:
ftp://download.epson-europe.com/pub/download/205/epson20540eu.pdf
Sep 11, 2009 | Epson Aculaser C1100 Printer
Epson C1100 Photoconductor kill chip
You can buy a new chip , empty the waste toner and then keep printing. Its only if the message is "replace photocnductor " though..
http://www.tonerangel.us/instructions/default.aspx
Jan 07, 2009 | Epson Aculaser C1100 Printer
Replace Photoconductor
There are several "doors" on the C1100. You need to open the door on the top. You will see an orange handle on top of the photoconductor, to lift it out. You can't lift it out, until you've pulled the orange handle on the far right up first. You then need to buy a new photoconductor - these are £150 - £180 ish. There are cheaper solutions, such as just replacing the "killer chip", which tells the printer how many sheets you've printed, but in my experience, the replacement chips soon become faulty, and render the printer useless. I know it sounds a lot of money to replace the photoconductor, but you need to do a lot of printing before it's time to replace it.
Nov 03, 2008 | Epson Aculaser C1100 Printer
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Solution to epson c1100 error message
Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
Pls dnt 4get to rate solution. TY
Mar 18, 2008 | Epson Aculaser C1100 Printer
Worn Photoconductor Epson C1900 laser Printer
hi this solution has already been covered in full lengths. Epson c900 and c1900 are similar. have a look at my posting on this. photoconductor reseting by Labatt in this forum. read from the start.
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Jan 29, 2008 | Epson AcuLaser C900 Printer
587 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
