Maytag Neptune Washer
Problem for Maytag Neptune Washer
Maytag Neptune Max Extract Quit Working
By bc28739 on Mar 30, 2007
Maytag Neptune MAH3000AWW - new fall of 1998.
Max Extract feature is no longer working. I've removed the front - belt is fine - everything looks normal.
With the door off, holding the door switch, and running the "spin" cycle (either one) - the drum rotates stops reverses direction, pauses for about a minute and then repeats. This action is the same either with or without the 'Max Extract' button depressed.
Water pump is running - eveything else seems normal.
Is there a suspect position on the control board? - are there wires below that would allow me to test whther the switch is making the circuit it should?
Any advice would be helpful.
Same Problem
May 03, 2008
-   max extract never engages, spins back and forth and water is pumped out, closes are very wet, belt is okay...-   skyler64
Feb 24, 2008
-   washer runs normal until it gets to spin cycle. pump runs and no spin. took back off and looked at very clean inside. no connections loose that I can see. it did have a loud spin cycle before as in a off ballenced drum. can not remember if normal or not. lost manual for it.-   toothpik
Feb 24, 2008
-   im having the same problem. I usually have to have to put it on another spin cycle to remove water-   dznow
Solution #1
posted on Oct 18, 2009
Not Rated)
wmheinz
Rank: Apprentice
Rating: 0%, 0 votes
More information about the problem is needed...there are two levels of spinning..."regular" and "Max Extract" The Max setting spins the tub much faster. If you are having trouble with really wet clothes being left in the washer...haven't really been spun at all...this might have a couple of solutions. First, check the "out of balance" switch (a little plastic square with two green wires attached) located at the base of the tub on the front on my stacked unit. Because of the vibration in the tub, the wires on mine have broken twice.right at the switch. The other possibility is the main circuit board. Check out the internet for solutions/replacements.
My washer's Max setting is not working...and I don't know the reason for this...any help? Thanks...
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune Washer
Questions and Unsolved Problems for Maytag Neptune Washer
Do you recommend Maytag Neptune Washer?
Answer
Answer
My Maytag neptune washer door is locked, and will not open. Have turned the washer off, unplugged it... (More)
Answer
maytag lat9606age top loader sometimes won't spin, instead it will agitate. motor seems to run the... (More)
Answer
We have a Matag Neptune washer - model # MAH4000AWW - -It is about 10 years old. When we do the... (More)
Answer
I have a MAH4000AWW and it starts and stops in mid cycle and sometimes it drains and sometimes it... (More)
Answer
Hello, I have a 12 year old Neptune front loader makes a short buzz sound when washing right before... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
