Question about ASUS A7N8X-X Motherboard
Asus-A7N8X-X problems Hey mate. my problem is that when i turn in my computer it says you have not connected your power cable to your video card?? please help ;D //gr?nh?j
  • g_ronhoj Dec 19, 2008
    thx m8 very helpfull. well now my problem is the power switch connector won't work proberly, i have to pull it out of the motherboard and put it in again, and then the computer starts on it own??
  • 827 Answers
Hey there,
My name's Chris, from Scotland.
I have a graphics card on one of my computers, that needed one of the power cable from the powerpack to be plugged into the end of it. Just open up your computer and you'll see a few of these power cables free for plugging into various devices, such as hard drives and disk drives. Take one and plug it into the video card itself, there will be a slot that fits. Push it in firmly.
If you think that there is already one plugged into the card, then replace it with a different one.
Now reboot.
It should work now.
Hope this helps
Chris (ziraffa)
Posted on Dec 19, 2008
Ge force 9500gt, 512mb, ddr2 compatible with asus a7n8x deluxe
The ASUS A7N8X only supports AGP8X, the 9500GT is PCI Express. There is no way the 9500GT will work with this board.
Dec 12, 2011 | ASUS NVIDIA GeForce 9500GT, (512 MB) PCI...
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Computer boot problem
Temporarily swapping-in another power-supply is the first thing to try.
Don't connect the disk-drives, CD/DVD drive, nor 3.5-inch drive.
If the computer "beeps", and shows the POST (Power On Self Test) screen, then changing the power-supply is the solution.
Look at the motherboard -- any "blown" or "bulging" capacitors?
Oct 27, 2009 | ASUS A7N8X-E Deluxe Motherboard
Asus a7n8x-e deluxe, nvidia geforce 6800gt 512 - OS doesn't start
Try to start your computer into a safe mode and then remove the old graphic card driver but if you cant get to safe mode then probably theres a problem with your operating system. Consider reformat and install a fresh copy of any OS you prefered.
Oct 23, 2009 | Computers & Internet
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
Asus a7n8x-x motherboard monitor will not fire up.{monitor}light just keeps blinking no picture. any takers?
Ensure that the AGP video card is seated all the way -that is a common problem with AGP cards. If you suspect the video card then try to find a PCI video card if you don't have another AGP card. This is the most direct way of isolating this problem. Best of luck to you, Steve Medley
Nov 08, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
What wireless card to connect to A7N8X-E deluxe ?
From Asus website:
"The Wi-Fi slot is specifically designed for the ASUS Wireless LAN add-on card"
Nov 05, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
ASUS A7N8X-X Motherboard Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
