Question about Mercury KVM800M Motherboard
Unable to detect 160GB SATA HD... as the message says "the number of disks is not adequate to create a RAID " Please help me outta this problem
    Problem Solver:
  • 17 Answers
You need to go into your bios and change it from RAID mode to IDE(yes i know youre using a sata). when your computer first turns on you should be able to see which key you need to press to enter your bios.
Posted on Dec 19, 2008
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
I want to install RHEL3.0 in SATA DeskStart HD using MSI SATA MB, but not detecting at OS installation time. HOW i can detect, Pls help me!!!!
You need to create a space for which to install Linux. That likely means resizing Windows. Partition Magic is a good Windows utility to accomplish this, although there is a Linux version called Gaprtedthat will do essentially the same thing. You download the Gparted live cd, burn to disk, and run it from your computer. You must go into "setup" and set your Bios to boot from CDROM before booting the Hard Drive. Once booted, follow the on screen instructions. Resize Windows, (but NOT before a thorough defrag of your Windows drive), and create a "blank space" for Linux. Afterward, boot your Linux distro, (RedHat 9 was a great distro, but a newer version of a Red Hat based distro would serve you better, sayCentOS or Fedora Core), and follow the online instructions. Good Luck!
Sep 25, 2008 | MSI 945GM2 H-F (816909015911) Motherboard
Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Aug 30, 2008 | Intel Motherboard
Corrupted Program
when you reboot, go through F2..and see what's showing there first..
Mar 21, 2008 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Raid
I might guess two things: 1. the battery failed (and has been replaced), 2. the motherboard has both SATA and IDE sockets for hard disks and you are using IDE.
If the latter, (and the BIOS settings were lost when the battery went) the BIOS setting would default to SATA hard disks and produce the mesage in the POST screen of, 'The number of disks is not adequate to create a RAID array' and no keys will work in the POST screen except ESC.
Repeatedly press DELETE (on most computers) on start up, ignore the POST screen, and the BIOS settings screen will come up. Check the date and reset, then goto INTERGRATED PERIPHERALS and reset SATA to IDE, save and exit. This cured my problem.
Feb 27, 2008 | ASUS K8V-MX Motherboard
Mercury KVM800M Motherboard Logo
130 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
