Question about Timex Outdoor Casual Expedition® Aluminum Trail 46461 Wrist Watch
Shorten watchband How do I shorten the watch band on this watch. Way too big for my son's wrist. Detached the one end from the latch but can't figure out how to remove links
  • 1 more comment
  • Anonymous Jun 15, 2008
    Shortening a Timex watch band with arrows
  • Anonymous Mar 18, 2014
    How to shorten the rubber band
  • Anonymous Mar 25, 2014
    I purchased a Speidel watchband [177DR SLOT 136] I am using it to replace a damaged band on a Timex Watch. The problem is I have a small wrist and need to remove some links to shorten the band. How do I remove the links? Any help would be appreciated. Thanks,
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Posted on Jun 28, 2008
    New Friend:
  • 40 Answers
It probably is a pin that is holding the links together. When you look on the inside of the band is there an arrows pointing in one direction. If so then you need to push out the pins in that direction and then put them back in the opposite direction.
Posted on Apr 05, 2007
  • 51 Answers
You can find here step-by-step instructions with pictures:
How to shorten a metal watchband
It is for a casio watch, but the watchband has the same principle with "arrows" on the links.
Posted on Sep 13, 2008
SOURCE:
Removing wrist band
You can remove any watchband using a pocket knife trying to get between the back side of the band and the watch. Gently pry sideways until you see the spring-loaded end coming out. Flex the band back from the watch as you do this action.
Nov 28, 2013 | Fossil CH2332 Wrist Watch
Two watches: can not find a 22 in wrist band for this one
Watchband Solutions can probably help you. Their website is
www.watchbandhq.com
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 11, 2010 | Peugeot 288BK Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Remove links on this watch
    Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
    May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
    How do I shorten the watchband to fit my wrist?
    If you turn the band inside out...and stretch it...you will see either 2 or 4 small tabs per section. Use a jewelers screwdriver to lift up each tab per section and slide that section out. Now it will be easy to take other sections out as you won't have to maintain pressure on the band. Reassembly is reverse order.
    Apr 24, 2009 | Watches
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    Take link ot of watchband
    take it to a jeweler because if you do it your self your warranty is no longer valid
    Jan 06, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    Timex Outdoor Casual Expedition® Aluminum Trail 46461 Wrist Watch Logo
    2,429 people viewed this question
    Top Timex Watches Experts
    freddyfox
    Jerry Greenberg
    Jerry Greenberg
    Dustin
    Dustin
    Are you a Timex Watch Expert? Answer questions, earn points and help others
