Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
I have a TLKR-T3 and a T5720 radios. can they communicate? Thanks
  • mkvanderpool Jan 15, 2009
    I have a set of Motorola Talkabout 200 radios and a set of Presidian (Radio Shack) radios. And even though they have the same Channel Frequencies they don't want to communicate with each other. Is there a way around this? Codes etc?
  • Motorola Master
  • 1,654 Answers
No, they have no frequencies in common. The TLKR-T3 uses the PMR446 frequencies common in Europe. The T5720 uses FRS freqeuncies common in the USA.
Posted on Dec 19, 2008
Motorola TLKR T3 one way not working but Monitor works...
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Nov 20, 2012 | Motorola Radio Communications
Hi, i have 2 TLKR-T3 and i cant tune it ,so what can i do? and how can i reset it? thanks in advance
Try setting the radio back to a simple mode of operation. Shut off all special features such as the sub-code (interference eliminator code), VOX, room monitor, and call tones. Go to just one basic channel, such as channel one. Then check to see if the radios talk to one another. If not, check your battery packs, as it takes more energy to transmit than to receive. Swap battery packs and see if the problem moves to the other radio. And lastly, get a third radio involved to see if one of your radios is simply defective.
For your convenience here is a link to the user guide: http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Best regards.
Aug 31, 2011 | Motorola TLKR T5 Two Way Radio
My TLKR-T3 does not work. One of them is possible only receive menssagem ( Receive the transmission ). So it is not possible to transmit zero messanger. Seems that the microphone is not...
Check your programming. The frequency and code must be identical on the two radios. Here is a link to the user guide http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
The description you give is indiciative of the code being set differently between the two radios. For basic operation set the code to off (zero).
Best regards.
Nov 04, 2010 | Motorola TLKR T5 Two Way Radio
One of my tlkr-t3 walkie talkie's will not recieve.
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
Feb 27, 2010 | Motorola Radio Communications
TLK3 T3 Motorola permanent static noise
The "MONITOR" is probably stuck on. You can go to
http://www.mods.dk/manual.php?brand=motorola and login (its free) and download the manual and look for how to turn off the "MONITOR" function.
Nov 02, 2009 | Motorola TLKR T5 Two Way Radio
Motorola TLKR T3 communication problem
svp dite moi comment les refaire marcher car il y en a un qui recoit tout et l'autre rien du tou svp aider moi
Oct 04, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola tlkr t3 both units power up ok they are
Your PL or DPL is not set correctly.
Check your owners manual, you can set this with the user buttons on the radio.
Press and hold the PTT button while turning the radio on. this will put the radio in the programing mode.
Be careful, if you do not know how to set the PL DPL or frequency you could make the problem worse.
Aug 03, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
749 people viewed this question
Top Motorola Radio Communications Experts
Steve
Jose Ma DM.
Jose Ma DM.
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
