This is Rajnish here, sir i'm having problem with my Kingston 8 GB pen drive. The problem is, when i insert my pen drive my system detects it properly. but when i transfer any data to the pen drive, it shows copying the file but as 2 or 3 progress bar moves, it suddenly shows an error ''the file or path is not correct, make sure you've given the correct path''. Now when i check the property then it shows ''used space 0 Byte And Free Space 0 Byte''. When i format the pen drive, property shows ''7.65 GB is free and 0 Byte'' used. And Again when i transfer the data to the pen drive same problem occurs. There is no problem with da pendrive cause i checked it on other system it works properly (Write the data as well as read the data). I'm only able to read the data with the pen drive on my system only if the data was written on other system.
I thought there would be problem with my operating system files or driver so i formatted my full PC and repartitioned but no change. And when i insert any other pen drive to my PC, it works properly. I also checked the pendrive on other USB port available in my system but still i'm getting the same problem.
My system configuration:
OS: MS Windows XP Pro Service pack 2.
Processor: AMD athelon 5000+
Motherboard: Asus A8N-MX
What would be the reason causing this problem and if there is problem with hardware settings then please help me to find the solution or remadies
I'll be thankful of yours.
Rajnish
Comments:
Dec 20, 2008
- Thank you for replying me.
Sir i've had formatted my hard drive with NTFS and i always used to format my pen drive with FAT32. But still the same problem.
What would be the appropriate solution for this problem please suggest me.
