Question about iLO XM-MP3-CD Car Stereo
Boat stereo/speakers I recently had my boat anchored a few feet off shore while sitting on the beach. I turned the speakers up in order to here the stereo from shore. It was loud but not obnoxious. Suddenly the sound stopped. When I approached the boat to inspect the problem I could still here the music but it was distant and very quiet within both speakers? Thanks, David
  • David Gonzalez Apr 02, 2007
    After a bit of testing I found the speakers were bad. Each speaker had small transistor which must have burnt out due to age and the
    loud volume.
    Thanks,
    Heavy
  • 247 Answers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Posted on Mar 30, 2007
Radio model plcdbt65mrw.. I replaced this radio in my boat with the existing.. did wire for wire.. Excessive static coming thru speakers.. what can I check..? thanks mike
There are many possible reasons. Few pointers.
Disconnect antenna and check for static. If it is still there then turn off everything on boat , including battery charger and check for static. If is gone then start turning on electrical devices to narrow what is causing electromagnetic interferencw. If your still have static then disconnect all speakers right on stereo harness. Start connecting speaker to individual output to check for static. If there is no static then one of speaker wire installed on boat is shorted somewhere. If you have static when connecting speaker straight to stereo harness then likely internal ampflier inside stereo is a problem
Aug 20, 2018 | Boating
What size motor for a 1970 15ft. seaswirl boat
outboard??? you could go all the way to 40 hp but id not recommend that much , but maybe a 20 hp would be just right !! its all about the condition/design of the transom and how you want the boat to sit in the water (weight) at rest ive seen motors as low as 10 hp on boats this size
Feb 29, 2016 | Boating
My new Coleman SCANOE sank.
Look up the "Bird Of Prey Canoe Stabilizer" on YouTube. For less than $80 a guy made stabilizers for this model of canoe. I'm looking into buying one and found your post. I have read in another area that people were having issues with it taking on water in the back while using a motor. We mostlly row, so at most I was considering a small trolling motor.
Jan 15, 2013 | Coleman Scanoe Canoe
Steering on starcraft fishing boat
Some one has assembled the rack to the wrong side of the steering wheel shaft, OR put the cable down the wrong side of the boat, OR switched from a pivot steering anchor to a transom mount anchor (you would have had a drag link left over.)
Jul 11, 2012 | Light Boating
I recently bought a boat with this type depth finder on it. It was working fine until I was unable to get off a local beach that people commonly pull up on. The water ran out and the entire bottom was...
Hi, make sure that the bottom of the transducer is parallel to the bottom of the boat. It probably has been knocked upwards while on the beach. If not the transducer will need to be replaced. Hope this helps, regards Phil.
Jun 06, 2011 | SI-TEX Sitex Cvs106lmkii Color Lcd With...
Geometry
I don't understand how this relate to Ecommerce Websites, but here is the answer:
c*c-b*b=a*a
The answer is the root of a
(100*100)-(50*50)=7500
root of 7500 is 86.6025403784439
Nov 17, 2008 | Computers & Internet
Clarion M335 display and CD work - suddenly no sound
Maybe it is a boat anchor. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Aug 14, 2017 | Clarion M335 CD Player
Marine stereo (Aquatronics) Turns on and then shuts itself off
aquatronics model ms-1000 led display lights and nothing else
Aug 05, 2007 | Aquatronics AMS602WR Coaxial Car Speaker
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
iLO XM-MP3-CD Car Stereo Logo
125 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Philip Armitage
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
