Question about Onkyo TX-DS575 Receiver
No Sound My unit began to have trouble switching between DSP channels. At one point if I kept on switching modes it would finally "kick in". I noticed a second switch click when the receiver "worked". I tried the headphones as well as the speaker test function. Niether option would give me sound so I tested the speakers separately and they worke just fine with another amplifier. Please advise. Any help would be appreciated. I would like to rescue this amp. I cant't get a new amp and would be out in the cold if this amp can't be resurrected. Thanks.
  • 1 more comment
  • crumjon Jan 02, 2008
    I am having the same issue...anyone have a fix other than sending it out?
  • nothing2008 May 13, 2008
    Onkyo TX-DS575 5.1 Receiver
    No Sound any channels but powers up.
  • Snoopbob Jun 12, 2008
    Same here...my unit is about five years old and this is the first time I've had trouble. Did anyone try to switch to B speakers but did not have the speakers connected? I think this is what I did to cause the failure. I suspect a protection circuit tripped but the protection indicator is not lit. Just a guess.
    New Friend:
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1, press Speaker A button.
4. You should see "CLEAR" on the display for a second and it will go on stand-by mode.
5. Turn on the unit and check if sound is back.
Hope this helps
Posted on Jul 07, 2008
  • 3 Answers
Hi, I just started having the same problems with my Onkyo TX-DS575. I have to play with the DSP buttons...the A/B speaker button...and now it has gotten to the point where my family and I lift the receiver up in the front, and slam it back down on the shelf and then hit the DSP buttons again and eventually we get some sound. This unit was already fixed once by Onkyo right after the 2 year warranty ran out for a similar problem. They returned it working...but scratched. This is the second Onkyo receiver that has died an early death within 15 years. I love Onkyo's styling, ease of use and sound, but I found the best way to solve this was by purchasing the Yamaha RX-V861 this week. I am done with Onkyo. Scotty D, Middletown, NJ
Posted on Aug 23, 2007
SOURCE:
Sound is shorting out...its not the cable that I am using I have no trouble with it in any other amp. The overdrive channel does not work at all. And randomly all the effects will just decide they want to...
It sounds like the DSP processor is either about to go out, or is mostly there. Have a qualified amplifier technician take a look at the DSP. Also look up the cost of a new one.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Hello how doi adjust the left and right balance for the left and right channel level
The only 'balance' is to adjust the channels relative to each other with the test tones.
http://www.retrevo.com/support/Pioneer-VSX-24TX-Receivers-manual/id/386ag014/t/2/
Page 29.
The "Effect/Channel Select" button on the Remote (left of the Menu button), will let you change the level to any channels while listening to a program. Page 22
"EFFECT/CH SEL +/- buttons (See p.38)
EFFECT : Use these buttons to increase or decrease
the amount of effect applied in a DSP or Advanced
Theater mode. When the amount of effect is
increased in a DSP/Advanced Theater mode the
characteristics of that mode become stronger and
more noticeable. The scale ranges from 10-90 with 70
as the default setting. First turn on the DSP/
Advanced Theater you want (by pressing the DSP/
Advanced Theater button until you get the mode) and
then increase or decrease the amount of effect.
CH SEL : You may want to adjust the channels when
listening to some sound sources. Use this button to
select the channel you want to adjust.
+/- : Use these buttons to select the amount of effect
in a sound mode and to adjust the channel"
Jan 16, 2011 | Pioneer VSX-24TX Receiver
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
There is a music button on the front panel that allows you to select Jazz Club, Live and concert hall. It cycles between these 3 options and every time it switches, the audio cuts out
Momentary cutout is normal when you switch between DSP modes (Digital Sound Processing). The unit has to crunch the numbers anew each time you change the parameters.
Nov 28, 2009 | Sony STR-DE997 7.1 Channels Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
No fm reception
We had trouble switching from AM to FM. We finally solved the problem by pushing the reset button on the back of the unit (any sharp pointed object can be used to engage the reset button). Do this followed by setting the mode to FM and try tuning in your FM stations. Try the procedure several times and it may finally kick in, as was the case with us getting our AM stations
Dec 30, 2007 | GPX HM3817DT Shelf System
XM 2 GO Not Playing
I had the same problem. I had to reset (use a paper clip into the RESET hole under the battery cover ( or pull out the battery for a a couple of minutes). Then, after recording some songs, I switched over MYXM and then began rotating the channel selector dial. The volume indicator arrow moved off zero and began advancing up the volume scale. I kept doing it until it about half way and my sound was back.
Nov 21, 2006 | Pioneer AirWave XM2Go Satellite Radio...
Onkyo TX-DS575 Receiver Logo
640 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
