Question about Sony Cyber-shot DSC-W50 Digital Camera
Orangr light there is an orange light that comes on every time i go to use my flash on camera. i have tried to fix it but it keeps on coming back. my camera is a sony cyber shot mocel number DSC-W50. please if there is anyone that can help please do. also how do i go about getting an instruction book for this camera.
It is the auto focus light. The sensor needs it in order for the camera to figure out how to adjust the lens.
Posted on Apr 21, 2007
Seems like you have the AF Illuminator set to on in the SET UP. This lights up every time the camera thinks it is not light enough, gives more brightness to the picture!
Posted on Mar 30, 2007
Recently my Canon camera stopped taking pictures. It will take a picture if the flash isn't needed or of you turn the flash off; however, if the flash is needed, the orange flash light will come on...
If your camera is under warranty bring it to the nearest Canon Agency to have it check and repair. Most of the time the problem is mechanical and only the qualified technician can fix it.
Jun 19, 2011 | Canon Cameras
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
My Ac Adapter i think is broken and my Xbox wont turn on but the AC adapter has a orange light that when i unplug it the orange light still does not go off.
Hi if the main brick has got an orange light then this is telling you the mains lead is working so try doing the following
1 unplug all leads from back of xbox and turn the power brick off at mains
2 plug the power lead back into the xbox, now when you push it in and it stops try pushing it in a little bit further usually they just dont push in far enough and it can be quite tight so make sure you are pushing it in hard enough,
3 now plug the video lead in and try switching it on,
keep an eye on the orange light whilst you switch it on if it comes on then it should continue to work if it dont come on watch the orange light and see it if changes color at the same time your switching it on, it will either flash green or red just once before going back to orange.
let me know what happens ok
Nov 28, 2010 | Microsoft Xbox 360 Console
Orange light keeps coming on and I cannot print anything. It gives an alert on my lap top to say USB non compliant. Canon ip 100 series. A non compliant device is connected to the direct port or...
try removing the camera software that was presumably installed.
If not, can you try a System Restore? Sys Restore will restore your laptop to an earlier time. Try a restore date prior to the date the problem first occurred. (Sys Restore in WInXP is accessed thru Start/Accessories/System Tools- Restore dates that you can use will be in BOLD font on the calendar)
Cheers,
Steve
Jul 11, 2010 | Canon iP100 Portable Printer
When I turn my IP 3000 on the green light only blink 9 time no orange light at all I did try to reset no sucess as the green light keep blinking 9 time any help
9 flashes should only occur if you are trying to print directly from a non-compatible digital camera. Check where your USB cable is plugged into the printer. The cable coming from the computer should go into a 'square' port in the back of the printer -- not the rectangular port on the lower right side of the front of the printer.
Nov 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
When i plug in my usb charger, the light flashes red green then orange. even without my battrie
try cleaning the battery(copper bits) try charging it on your lap top, it should flash red green orange, keep unplugging and plug back in again its worked for us
Jun 24, 2009 | Samsung NV3 Digital Camera
Check engine light
If Orange, ok, if flashing Orange, still OK to drive. If flashing RED, better not drive too far. Go to Auto-Zone; they read the codes AND print the explanation of the code; ...
... THEN, TAKE CARE OF PROBLEM ... do not just drive into hell.
Aug 22, 2008 | 1997 Volkswagen Jetta
Canon A540 flash charge not holding
Some of The Canon Powershot A530 and A540 cameras are subject to a advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Oct 25, 2007 | Canon PowerShot A540 Digital Camera
Lights are on but nobody's home!
I had the same problem two years ago and because the camera was still within warranty coverage, I was able to return it to Olympus for no charge repair and they fixed the zoom lens gear and it works fine.
Oct 14, 2007 | Olympus SP-320 Digital Camera
OLYMPUS 410
It is something that seems to be a problem with the Stylus 410s. Olympus will not repair them unless they are under warrenty, I've tried. My best advice, and what I am in the midst of myself (I have 2 of these with the same problem) is to file with the BBB. Perhaps if enough complaints come through, they will begin to fix the stylus 410 defect as they should. Good luck. =)
Oct 13, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
130 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
