Question about Canon PowerShot A70 Digital Camera
A70 Mode Switch Problem
I originally thought my camera was dead. I replaced with a newly charged set of batteries and still dead. Finally I took the camera apart to have a look. In the mean time I discovered that the charger had a 2 cell/4 cell switch, and only 2 batteries were charged. On reassembly, my mode switch stopped working. I disassembled again and found a broken lever on the mode microswitch. Finally located a new switch, replaced it and reassembled. It worked for one switch operation, then the same problem. I took the camera apart again, and again the switch lever was broken. Are there any reassembly tips or tricks to reassemble the camera ? Also are there any more sources for a new switch ?
  • 1 more comment
  • Jimmie Radel Apr 11, 2007
    I got the switch at US Camera. They were very good to deal with,
    http://www.uscamera.com/1can050_136.htm
    J
  • Jimmie Radel Apr 27, 2007
    I ordered another switch fromhttp://www.uscamera.com/1can050_136.htm
    After spending a lot of time scoping out the switch and lever positions. I have determined the proper position for the mode lever on the cover is the Camera position. Also on assembly of the back cover, go slow, and keep wiggling everything around. Slightly wiggle the mode lever back and forth, as the very delicate microswitch button/lever has to position itself correctly within the mode switch lever assembly. Do not just snap the lever back and forth between camera and review mode until you are sure everything is in position, or You will almost certainly break the micoswitch.
    I installed the back with the Camera fired up, so I could monitor if the mode switch was working.
    Anyway, the camera is working now !!
    J
  • bobo993 Jan 13, 2008
    How hard is it to take it apart. I have an A60 with the same problem. The camera still take pics fine so I don't want to wreck it taking it apart. How much risk is there is taking it apart?
  • 641 Answers
Posted on Jul 31, 2007
Lumix DMC-FZ18 wont power on
Leaving it in the on mode has totally depleted the battery, you say repeated charges fail. Usually leaving it on charge for overnight should revitalise it, if this is not so then the battery should be replaced as attempting to recharge it may cause it to split and spill nasty stuff onto things.
Dont take the risk with batteries in expensive cameras they are cheaper to replace than the camera itself. I remove the batteries from my camera at the end of any session and store them in a tupperware container in my camera gear. That way if they develop a problem it wont affect the camera. It also saves them from running down when the camera switch is left on.
Please rate my help++++Thanks for using FIXYA
Nov 23, 2009 | Nikon D300 Body Only Digital Camera
I TURN ON MY A70 AND I GET A VIEW OF THE LAST PICTURE I TO TOOK.
The camera is stuck in picture review mode. Try sliding the mode switch back and forth a couple times, and leave it in camera mode to see if this corrects the problem.
Apr 02, 2009 | Canon PowerShot A70 Digital Camera
Rechargable batteries drain as soon as they are put in the camera
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Nov 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Help
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 28, 2008 | Canon PowerShot S1 IS Digital Camera
Viewer mode is not working
The CCD is on the fritz. Go to canon website, there is a bulletin and they will repair regardless of age
Nov 01, 2007 | Canon PowerShot A70 Digital Camera
Repost of A70 Mode Switch Problem
Make sure that the mode switch on the cover is in the playback position. Unfortunately, I don't have a source for new switches.
Apr 24, 2007 | Canon PowerShot A70 Digital Camera
A70 will no longer switch to the "view picture" mode anymore. Camera was dropped
Here's a disassembly guide for your camera. It's in Estonian, but has lots of pictures to show you the steps to get in there. If you do get it open, try not to touch any of the elctrical connections or you might get a small shock from the flash capacitor.
http://qman.fotokala.ee/Kaamerad/PowerShotA70/index.html
Nov 17, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
159 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
