Question about Krups FDD912-75 Expert Belgian Waffle Maker
Krups FDD912-75 Expert Belgian Waffle Maker not heating properly
I have Krups FDD912-75 Expert Belgian Waffle Maker, i have been using it for 5 months in my coffe shop and 2 days ago it statred not heating.
i already one one more as well and it had similar problem 5 months ago and it s not heating properly to cook belgium waffles.
i asked to an electrician and he checked and said that the elements are working properly.
so he said the problem should be the thermostat.
i dont know what to do and i am desperate cos thos krup waffle model is not on sale in united kingdom.
i bought it from germany.
anyone who has a comment , i will be glad if you can share your comments..
many thanks
farfield
  • 462 Answers
SOURCE: Dead krups waffle iron
That is probably a thermal fuse. It is designed to open and stop heaters from working incase of over heat condition.
Meaning if you did not leave the appliance on too long with nothiung in it, the thermostat may be not opening at correct temp or the fuse was in a place where it got over heated or the fuse was weak.
You can replace it 1 time see if it worked ok but if it goes out again and you didn't see anything this time best replace it. Especially if under $50.00. Thermostat will probably run 1/2 of that. Thermal fuse 3 to 10. Try a heating AC parts store and take the old party with you.
If this helps you please help me by rating me as high as you can. Thanks for using fix ya.
Posted on May 06, 2009
  • 33 Answers
SOURCE: How do you know when it is done cooking?
Usually there is steam rising from the waffle maker when cooking, if there is no light on it to tell you when it is done watch the seam and as it is getting done there will be less steam than when it first started, if there is a light watch when it goes off or when the steam stops and then count minutes to when you open it to see how browned toasted you prefer
Posted on May 21, 2009
miket756
  • 2702 Answers
SOURCE: I don't know when my waffle is done
it will have a warning signal on it,,,,,its called smoke?
even flames if its realy desprate!!!
the thing is its cooking,,, and thats not an exact sciences, so realy you just lift the lid to have a look, just like you test a cake, stab it with a knife? and flick it with your finger,, if it rings its cooked
Posted on Feb 16, 2010
mcdevito75
  • 1970 Answers
SOURCE: I'm looking for the instructions that came with
mcdevito75 here, BEST BET, contact Krups customer service at 800-526-5377 Hope this helps.
Posted on Jul 11, 2010
SOURCE: I bought a Krups Household Type Waffle Maker at a
I think this is why people make pancakes. =) Cleaning the waffle iron is a real pain. My waffle maker looks exactly like the one you have pictured. Mine also came with no instructions because its my fiance's. As far as how much batter to use, you should use a ladle and through trial and error figure out how much is the best amount. I would guesstimate approximately 1/4 c. For cleaning the overspill, from what I have read online, everyone says to unplug the iron (obviously) and wait until the waffle iron has completely cooled before cleaning. I have cleaned the back of the unit (where the coils are, which unfortunately got flooded with batter the first time) with a damp kitchen brush, damp sponge, and paper towels. Its messy and time consuming to clean up. You can get in the coils better with an old toothbrush or a very small bottle cleaner (like the kind you would buy to clean cake decorator tips). I just use warm water to remove the batter/gunk. I use a sponge (damp with warm water) to clean the baking plates. I towel dry everything after its clean, and clean the outside with a little windex so it stays nice and shiny. Good luck! I also recommend making lots of extra waffles and freezing them, so you can avoid as much waffle clean-up as possible. ;) You can heat them up in the toaster like Eggos. They stay good in the freezer for up to 6 months.
Posted on Sep 21, 2010
Testimonial: "Thanks for your advice. I was trying to unscrew the waffle maker so I could get in the nook, but it won't come apart. I used 3/4 cup batter!"
What is an accuracte Price for a Betty Crocker Belgian Waffle Maker 1957?
There are some listed on ebay. I don't think they are made using the Betty Crocker name any more.
Link to Ebay
1result for betty crocker belgian waffle maker
Aug 01, 2014 | Betty Crocker BC-1957 Belgian Waffle Maker...
Need a hinge pin for hinge opposite the handle it is broken
Buy a new waffle maker. I have the same problem. Got by with one broken hinge for a few years, but now the 2nd is broken. Called the company & there are no replacement parts available (looks like the hinge was a common problem). After looking around online, I'm not able to track anything down.
I've personally narrowed my choices down to:
The Caphalon No Peek Round Waffle Maker
Proctor-Silex 26500Y Belgian Waffle Maker
Black & Decker Chrome Belgian Waffle Maker WMB505
Cuisinart WMR-CA Round Classic Waffle Maker
Feb 17, 2013 | Faberware FWM800P Deluxe Chrome Belgian...
The waffles stick and separate when I open the top
You really have to use a release agent, like pam. Waffles have a ton of surface area that needs to release.
Jan 24, 2011 | Krups FDD912-75 Expert Belgian Waffle...
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
I'm looking for the instructions that came with the Krups 653-73 two-waffle maker.
Jul 11, 2010 | Krups 653 Chrome Belgian Waffle Maker
Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Jan 19, 2008 | Waring WMK300 Professional Belgian Waffle...
Krups FDD912-75 Expert Belgian Waffle Maker Logo
96 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
