Question about Labtec Pulse 285 Computer Speakers
Can i conect my labtech pulse 285 speakers to tv or dvd ?
    President:
  • 2,653 Answers
Yes, as long as the plug fits you can.
Let me know if you have any other questions.
Best of luck!
Posted on Mar 04, 2009
3 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: speakers conection
Yes, as long as you can plug it in, it will work.
If you have any more questions, please feel free to ask.
Posted on Mar 03, 2009
RescueTechLA
  • 2653 Answers
SOURCE: speakers conect to tv
Computer does not recognize speakers after reinstalling winXP
Install the software for the sound card. XP has no support without it.
Oct 03, 2017 | Labtec Pulse 285 Computer Speakers
Reinstalling speakers onto my computer
there is one calbe that goes to the computer its plug is green plug it in the green port on the back of the computer.
Apr 23, 2009 | Labtec Pulse 285 Computer Speakers
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Speakers conect to tv
Dec 19, 2008 | Labtec Pulse 285 Computer Speakers
Speakers conection
Labte pulse 285 speakers!
You won't find drivers for these Labtec speakers because they don't exist.They are plug-and-play speakers so they should work as soon as you plug them into your computer. But I have the same problem as you do (I had to format my comp as well and now I'm screwed because the speakers aren't recognized by the computer).
Nov 02, 2008 | Labtec Pulse 285 Computer Speakers
Speakers
  1. first findout the problem is due to speaker or from your computer soun driver or hardware.
  2. for checking speaker, connect to an ipod or walkman to the speaker input if it works the speaker is okay
  3. check the computer sound driver software may installed properly
  4. for these type dxdiag on run in the start menu
  5. check the sound driver problem, if it re install the sound driver by using its cd
Jan 18, 2008 | Labtec Pulse 285 Computer Speakers
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Jun 19, 2006 | Logitech Z-680 Computer Speakers
Labtec Pulse 285 Computer Speakers Logo
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
