Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Generator is burning oil and choking out
I HAVE A BRIGGS AND STRATTON 5550 WATT GENERATOR 10 HP THAT WAS RUNNING WELL AND MY SON FILLED IT AND SINCE THEN IT SMOKES TERRIBLY WHEN RUNNING AND WILL ONLY RUN FOR SHORT PERIODS BEFORE CHOKING OUT. I FOUND OIL IN THE AIR FILTER AREA AND OIL COMES OUT OF THE LINE FROM THE OHV TO THE CARB.
    New Friend:
My gnerators burning oil iam start generator not smok then why oil burning oil please help solution
Posted on Sep 21, 2013
  • Nikoro Orire
    Nikoro Orire Oct 15, 2013
    What is the solution?
  • Nikoro Orire
Bad Gas Mixer....if Two Cycle.....Burning Gas/Oil mix if Four Cycle.....Got The Gas Cans Mixed Up Dude...or Dudess
Posted on Nov 11, 2011
  • basitmemon Sep 21, 2013
    my gnerators burning oil iam start generator not smok then why oil burning oil please help solution
    Scholar:
  • 75 Answers
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Posted on Dec 19, 2008
10 hp b&s engine will not run with choke open
Sounds like your carb needs rebuilt .This condition is caused by blockage of ports and jets in the carb .Running a fuel stabilizer will help prevent this .
Feb 13, 2012 | Briggs & Stratton Briggs Stratton 6200...
Briggs 5550 model 030253 generator spits oil
I'll take guess here, broken ring. You did mention where it was spitting oil from? GB...stewbison
Sep 05, 2011 | Briggs & Stratton Power Products 5,550...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
May 01, 2011 | Briggs & Stratton Briggs and Stratton...
TROT-BILT 7800 WATT GEN. ONLY RUNS ON FULL CHOKE
Hello, your main jet is plugged with varnish or corroded with water. You need to remove the float bowl and see which it is and clean it. That will fix your problem.
Feb 06, 2011 | Briggs & Stratton Briggs Stratton 6200...
I have a 5550 Watts Briggs & Stratton that only ran since purchase for 2 hours tops The pull starter locked up when I tried to start engine.
unscrew the four bolts holding it on and chek the rope has not become tangled dont unscrew the centre bolt as the recoil spring will suddenly shoot out everywhere
Mar 20, 2010 | Briggs & Stratton Power Products 5,550...
Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
Wont start. sprayed stater fluid but wont stay running
Your carb needs cleaned out. Tke it off and clean it out well with a good carb cleaner and you should be fine
Feb 06, 2010 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
1,254 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
