Philips Plasma TV model 42PF7520D
Have a digital camera and trying to view pics through the TV via AV on side connections of the TV with cables supplied with camera. TV will not let me choose the AV option. Camera switched on and on right setting (as shown in manual) but nothing appearing on TV. Any suggestions please?
SOURCE: Camera is froze up
i have been having this problem for a while...the issue is the memory card remove any card you installed for power up and then insert it later, should be fine
Posted on Jan 14, 2008
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
SOURCE: Philips Plasma NO LIFE
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Posted on Feb 08, 2009
SeanAnthony
SOURCE: 50 inch plasma blank screen
I bought my Philips Magnavox 50" plasma in June of 2007. In february of 2009, I noticed increasingly longer delays in the video coming on after turning on the power and then the audio began to delay coming on. After a few weeks of this problem the audio and video then stopped coming on at all. However, there was power going to the unit because the green power light was working. I noticed over 50 other consumers on this website had the same problem. WITH THE HELP OF OTHERS ON THIS WEBSITE, I HAVE FIXED THE PROBLEM FOR $40. YES, FOR LESS THAN $100.00 I HAVE A WORKING HDTV AGAIN, BUT WITH NO THANKS TO PHILIPS - MAGNAVOX. THEY WERE USELESS.
HERE IS THE FIX:
1. Unplug your power supply cord.
2. Remove back panel on your HD.
3. Look for capacitors that have a bubbled or slightly raised and rounded top. This indicates the capacitors have overheated or leaked and need to be replaced. The normal look is a flat surface with no raised features at all. (I had two bad capacitors that were side-by-side and identical: 3300uf 10v. Also, they should be located on the power supply board. My power supply board is in the middle of my 50" plasma.)
4. Go to an electronics repair store or Radio Shack and see if they carry your capacitor type and size and replace them yourself if you are comfortable with removing the capacitors and soldering new ones to the power supply board. The capacitors will cost you $2.00 each or less.
5. I was not comfortable replacing the capacitors myself so I removed the power supply board by removing the screws and unplugging several wire connections. This was not difficult at all. I then brought the power supply board to a local electronics shop that did repairs on HDTVs and simply asked them to remove the bad capacitors and solder two new capacitors onto the power supply board. They did it for $40, which included cost for the 2 new capacitors, while I waited and it only took about 10 minutes.
6. I replaced the power supply board and back panel of TV and it worked!!!
Some people on this sight suggested replacing the capacitors with some that have higher temperature ratings. Based on that advice, I wanted to replace my two that were bad (3300uf 10v) with two rated at 4700uf 35v, but my electronics guy suggested against it. Instead, I replaced mine with 3300uf 50v, with the only difference from the original parts being the higher voltage (50v instead of 10v). I figure if the problem occurs again, I now know I can get it fixed for less than $50.00. Philips - Magnavox should be ashamed for such poor customer service and not telling people about this simple fix. When I called their customer service support number I was simply directed to a repair place --over two hours away!!!
Posted on Mar 05, 2009
SOURCE: Problem transferring photos from my digital camera to my PC
Be sure that you plug original Olympus USB cable directly into USB port on mother board (ussualy on the back side of PC) not on the front pannel hub and not into extention USB cable.
Posted on Mar 23, 2009
My grandma has recently been gifted a Polaroid TV as a Christmas gift. When the free view channels had the TV reset she lost the signal to an outdoor cctv camera for the building. We can't seem to get it...
probably the camera is either analogue or video . How was it connected to the TV via the Aerial Cable or via an AV input
If the camera is Analogue it may be on a ATV channel. So you would need to switch the input Source on the remote for the tv and check the ATV channels. If it was on a AV then try checking the AV input sources.
The free view channels is probably DTV source . .
Jan 23, 2015 | Televison & Video
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
I have just had sky HD box installed but need a DVI to HDMI converter, however i cannot locate a one that fits my philips 42pf7520d tv.
I would expect most shops to carry that connector Here some links - I would expect Maplin to have a cable - however, I cant find a image on there website - so heres some links to amazon, I used the online manual - let me know whats different about these DVI connections on the TV - look the same from the manual
  • http://www.amazon.co.uk/Labgear-Premium-Gold-Plated-Adaptor/dp/B000GHQO0C
  • http://www.amazon.co.uk/Premium-HDMI-Cable-Gold-Metre/dp/B000GDI6FC/ref=pd_cp_ce_2
heres the support site for that TV http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7520D/10&slg=en&scy=GB
Direct link to user manual http://download.p4c.philips.com/files/4/42pf7520d_10/42pf7520d_10_dfu_eng.pdf
Apr 07, 2010 | Philips Televison & Video
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
What camera setting is required to show photos on TV. I have the video cable connected.
Set camera in playback mode, connect AV cord in camera and hook it to AV-in of TV and select that AV input with TV remote to view camera picture in TV as its being shown in camera LCD.
Sep 19, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
When i press av on my remote control i have tv ext and digital options but where has the options for ext2 and 3 etc gone
Dont know your specific model, **** some new tv's will only allow access to av inputs that is connected with cables and a component. Move your cabling from ext 1 to ext 2 or 3 and see if you can access the av ext. If still no access on ext 2/3 the av input board or backup memory could be faulty.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
Picture in Picture
Does you 9631 have 2 HDMI ports ? And are u trying to use both HDMI ports at once trying to use the pic in pic feature ? The processor might not be able to process both HDMI signals at once. Try using the tuner (a tv channel and a AV connection ) and see if you have the same problem).
May 05, 2008 | Philips 42PF9631D 42 in. Plasma Television
How can I playback and edit the captured movies?
The movies can be played back on the DiMAGE Z3. They also can be viewed on TV by connecting the camera and TV via the AV cable. Playing back movies on PC is enabled by installing the QuickTime, ArcSoft VideoImpression Version2 (Windows only), and DiMAGE Viewer
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
