Question about 3M Post-it Software Notes 2.1 Office Edition (70071034030) for PC
Want to remove post-it notes from my pc
I want to remove post-it mickrosoft notes from my pc
    Scholar:
  • 120 Answers
Microsoft has those things, well I want it.
If you don't want it, just switch it off from the Taskbar's Notification Area. Then disable it from Startup Programs. Or just uninstall using the Uninstall Shortcut in the program folder in start menu, or through Add or Remove Programs.
Posted on Dec 19, 2008
Presario CQ 40-613 AX note book, cop & scroll light flashing & no display
Unplug, remove battery, plug in, reboot. post results. Is the fan and vents free of dust? What is a "cop & scroll light flashing"? Have you done ANY updates, upgrades, damage?
Feb 07, 2013 | Computers & Internet
How to refill a pebble post it note dispenser
Please use the following steps to load the Post-It(R) Pebble-Shaped Pop-Up Note Dispenser:
1) In order to remove the lid from the dispenser you will need to twist the dispenser in half. While holding the top of the dispenser with one hand, use your other hand to support the base. You will need to twist the two part and then pull them apart to separate them.
2) Once the back is open, place one pad of Post-It(R) Pop-Up Notes into the top opening of the dispenser, feed the top sheet from the pad through the slot on the front panel. Make sure you are using Post-It(R) Pop-Up Notes and not the standard Post-It(R) Notes, as the standard notes do not have the alternating adhesive format and will not pop-up properly.
*Please note that we recommend that yo u use one pad at a time.
3) After the pad has been loaded into the dispenser, you can put the top cover over the base and twist them back into place.
Oct 25, 2012 | Office Equipment & Supplies
Cannot post comments on my desktop but can do so on my iPad. What is wrong?
They are different Operating Systems. Window vs iOS. Different features. However, Win 7 does have sticky notes. Like post-its. Download a sticky notes program if you don't have Win 7.
Oct 07, 2012 | Dell Studio 540 MT Pentium DualCore E5300...
Remove hard disc from dimension 3100c
David, this is the Service Manual for the Dell Dimension 3100 Desktop PC,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts.
Click on Harddrive
1) Pull the SATA power cable out of the back of the Harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ Note the L-shaped slot in the connector. Lines up with the L-shaped tab on the back if the Harddrive ]
2) Pull the SATA data cable out of the back of the Harddrive,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
[Top example is a SATA data cable. The bottom example is a SATA connector on the motherboard. Again note the L-shape in the connector.
The SATA power cable connector has 15 contact pins.
The SATA data cable connector has 7 ]
3) Now press the blue tabs (Clips) towards each other.
(Can also be said as -> Towards the middle of the harddrive )
4) Pull up, and out on the harddrive.
If I may ask, why are you removing it?
Post back in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | Dell Dimension 3100 PC Desktop
NEED MANUAL FOR SPEIGAL BROOKLURE OUTBOARD MOTOR MANUAL
Google the full model number of the unit with "manual" and note you may want to post a new question here as this one is in the PC desktop area--post in area with outboard motor etc.
Jun 06, 2012 | E-Machines etower 333i PC Desktop
How do I remove the motherboard from a HP Pavilion Media Center Model M8100n?
Follow my guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! note in the first section ESD. Now place the PC chassis on a table top, can use a cotton towel on the table top. Remove all the cables first. You might need to make a note of where they go. Now remove the Power supply. Then the RAM and graphics card. You should notice that there are screws holding your mainboard in place, remove them using a phillips screw driver. Now remove the CPU cooler and then using the CPU socket arm, remove the processor, be care full not to touch the pins or bend them. To install in the new mainboard the exact opposite.
Presto!!!!
Your done.
All the best
damnor01
Nov 15, 2010 | HP Pavilion M8100N PC Desktop
Thermostat replace
You didn't post your engine size so I will post the steps for the 3.4 and the 3.6L.
Below is for the 3.6L:
3.6L Engine
  1. Remove the air cleaner.
  2. Remove the throttle body assembly.
  3. Remove the heater pipes.
    NOTE Use a universal or swivel socket with a long extension in order to remove the bolts.
  4. Remove the coolant inlet pipe.
  5. Remove the thermostat bolts and the thermostat.
  6. Clean the thermostat and heater pipe sealing surfaces.
To install:
  1. Install a NEW thermostat gasket.
  2. Install the thermostat and gasket.
  3. Install the thermostat bolts and tighten them to 89 inch lbs. (10 Nm).
  4. Install the coolant inlet pipe.
  5. Install the heater pipes.
  6. Install the throttle body assembly.
  7. Install the air cleaner.
  8. Fill the cooling system.
Jan 10, 2010 | 2001 Pontiac Aztek
How to reset the bios on a lenovo 3000 C100 laptop
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Nov 17, 2009 | Lenovo 3000 C100 Notebook (S5374971) PC...
It won't install on either of my computers.
What part do you get stuck at and is there any error messages?
I suggest you try to uninstall (if it shows up in Add/Remove Programs), reboot and try again. Note any messages and post back.
Dec 03, 2008 | Computers & Internet
Computers & Internet Logo
687 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
