Question about Sony Cyber-shot DSC-W55 Digital Camera
Camera shutter not working
My camera comes on but says access and then says "turn off and then on again" i can only access my pictures but i can't take pictures.
Lens is sticking / stuck.
try gentle pressure to help pull out - if that does not work then try pushing lens in and powering on /off a few times.
keep trying!
I had the same problem - eventually got round it.
Posted on Jun 13, 2009
Camera worked just fine untill today. the pictures it takes is pitch black and every second photo it either comes up with message (something like d:3c85) or its just blank screen and cannot access...
I don't have a solution but I have the same problem, I think the shutter is stuck. I get the error D : 8805
Really sucks considering it worked earlier and I JUST got it...
Sep 15, 2011 | Olympus EVOLT E-410 Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 01, 2010 | Canon PowerShot A75 Digital Camera
Sony dscw130 lens wont come out
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Jul 06, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
Nikon d40x shutter problem
May be a weak subject to focus or the flash is not ready when you press the button.
Set the camera to auto(green) mode.Try it with a contrast bright subject for as many time as possible.
If the problem persists turn off the camera and reset the camera using the button near usb connection.
Then go to seller for replacement.
Mar 17, 2008 | Nikon D40x Digital Camera
Nikon D40 shutter is not releasing err is releasing butten again but same prob
I had the same problem. I sent my camera to the Nikon Service Center. They fixed it within three days. They actually replaced the whole aperture frame. FREE OF CHARGE AS LONG WITHIN THE WARRANTY PERIOD.
Jan 22, 2008 | Nikon D40x Digital Camera
LCD Display
I was cleaning my CCD and damaged the shutter. Same problem. Click to take a picture and the camera locks up and powers off. Turn the camera back on and the shutter releases and the camera resets and powers on. $281 service call later and Precision fixed it quickly. Replaced the shutter. They warranty their work for 6 months. Priced way too high, but nobody would touch it. As soon as I told other repair services how I messed it up, they turned me down. I had to much money invested in the camera to toss it in the closet.
Nov 24, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
My camera will turn on but the shutter won't open!
tiny bits of juice, remember? maybe (or I am sure) this tiny became corrosive inside the camera. (orange juice is the no.1 in my corrosive juice list, water is the least). You need to open and clean it, or a pro fix is necessary.
Sep 09, 2007 | Olympus FE-190 Digital Camera
Sony Cybershot DSC-W50
This is what sony cameras do when the lens has become jammed. There are multiple different reasons that the lens can jam but the result is the camera being unable to move it as expected and presenting that error message. Sometimes the lens can be manipulated gently (if extended at all) and freed from the jammed state. Failing this, disassembly is required. Check with your manufacturer for warranty service status and recalls. If they will not cover it you can find a repair provider online. David Millier Advance Camera Repair
Mar 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
145 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
