How to get glowing effect in coreldraw
Is it possible to get a glowing effect in corel?
And how to get 3d effect in corel ( for ex.say for a star) as it seems sometimes bevel like command does not work or does not work good?
  • kshameshwar Jan 29, 2009
    how get effect in coreldraw
  • 227 Answers
To create a glow: make a copy of your image you want to glow. paste to the side or original. select original. Convert to Bitmap, then use Gaussian blur, select pixel width of blur, preview it, then apply it when it look good. Put your copied image on top of the blurred image, bringing the copied image TO FRONT. voila NOTE change color of image to be bit-mapped BEFORE you convert to bitmap for a COLORED Glow
Posted on Mar 28, 2009
I need to replace the Beveled Gear for my Pro 600 mixer. it seemed an easy task. However, I am stuck in removing the Beveled gear. I cannot remove it after removing the retaining ring. help pls.
If you have the gear cases apart and the bevel gear exposed then you just push the planetary shaft up through the middle of the bevel gear. You will see that the shaft is driven by the gear via a loose fitting pin through the shaft. Pull the pin out (with fingers) and then the bevel gear will lift up off the shaft without the need to fully remove the shaft. Note the fibre spacer/thrust washer under the bevel gear between the bottom case and gear, don't lose it.
Aug 08, 2016 | KitchenAid Professional 600 6 Qt. Stand...
2001 f350 won't star unless pluged in
Sounds like it's the controller for the glow plugs, also, if the first glow plug in line from the controller is bad it will effect all the others. I've had this same sitituation, mine turned out to be the controller.
Jun 10, 2012 | 1993 Ford F350
CONVERT 2D TO 3D
If you just need the basic 2d to 3d conversion, I think a high definition video converter is a great and helpful tool, which can satisfy your demand of 2d to 3d conversion.
Jan 31, 2012 | Computers & Internet
How create 3d effect in illustrator cs3
Hi and thank you for using fixya
Here is how to do your 3d effect
1-open illustrator
2-create new document any size you like
3- create image or object you want to 3d on artboard
4-select object
5- click on the menu bar click effect then click 3d then click extrude and bevel
6- you will get a menu with all the different options for 3d
Have fun
Thank you
Mar 18, 2010 | Adobe Illustrator CS2 Full Version for PC
Corel 11 on a new mac, crashes often and some effects don't work.
One idea would be to run some updates from the Corel website, if there is an issue with the software this may sort it out.
Dec 01, 2009 | Corel Draw 11
Corel x2 problem: Unable to Load Library when sharing to VCD
Hey everyone, I faced the exact same, excruciatingly frustrating problem. After a quick search, I found forum threads telling me that when Corel Video Studio was modified to suit Vista, something about its 3D transitions got messed up.
So, if you face this problem while using Corel Video Studio on Vista, check that you have removed all 3D video transitions and try rendering again.
Jan 27, 2009 | Corel Paint Shop Pro Photo X2
Auto CAD 2000 3D modelling
i want to download vista xp theme on my comp. so what shall i do?
Nov 14, 2008 | Microsoft Windows Vista Ultimate Edition
3D Extrude and Bevel in Illustrator CS 3
Chances are you have chosen 'stroke' color as 'blank/empty' in the first pie chart, and 'stroke' color as 'black' in subsequent charts, by mistake. So as a result the charts are having a black outline. You simply have to select 'stroke' or 'outline' color as blank as you did in the first chart. Colors can be chosen in the 'swatches' palette, either for 'fill' or 'stroke' or both. Hope this solves the problem.
Dec 19, 2007 | Adobe Illustrator CS V11.0 for PC
Lately, all "white" objects, text, spaceships, etc. have "glows"
Do you also have a glow around the projected image, try projecting on a white wall without any borders. The cause for this is dirt inside the lens elements diffusing the light.
Oct 22, 2007 | InFocus ScreenPlay 4805 Multimedia...
Computers & Internet Logo
1,420 people viewed this question
David Payne
David Payne
