Question about D-Link Switch 24-Port 10/100MBPS
MY D-LINK 24 port swithch is not linking with any computers when i switch it on all the Green LED'd stays on permanently i am not getting any LAN links.Please guide me to solve this problem.
My usb hub did not working propely
Posted on Dec 19, 2008
D-link dsl 2640u
It could be a hardware problem, try Resetting the D-link back to the factory defaults and configure the D-link again.
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05)
Connect a LAN cable from the D-Link to your laptop computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access).
Now configure the wireless card in your computer laptop with the router's wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 05, 2013 | Computers & Internet
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
My DLink DI-604 router is not working properly. Lan port 1 I think is not working and only one computer connected to the router can connect to the internet. So I tried to remove all ethernet cables,...
Having an issue with your router or other equipment rented or purchased from Verizon Fios? Contact customer support service number 1-800-243-0019 for help. Our technical experts.
Apr 15, 2017 | D-Link (DI-711) Router
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How to check whether its working or not working?
If your PC LAN Card is active just connect the switch with Straight cable - & --you will see one yellow box in ritht side corner down to monitor screen...where the time appears.....also you can check in the Network Connections Folder. Or Right Click My Network Places> Properties> You will see local area Network....> Connected...then it is working if disconnected it's not working....Good Luck
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
I am not able creat Lan computer with D-Link Dir-300 wireless G router. We require lan for 4 Computers. One node is working with Wire less and other with cables. Previously I used D. Link Router
connect your wireless router with swithch with straight cabvle of lan. bt first connect your wifi router with any computerr so u can configure it as dhcp enabled.
Jan 03, 2009 | D-Link DES-3052P 48-Port 10/100 Managed...
D-Link Switch 24-Port 10/100MBPS Logo
171 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
