Question about Yamata FY14U4AD
Out side needle will not stich keeps gathering up fabric.
Help
    Problem Solver:
  • 9 Answers
Check to make sure the thread is between the tupper tension disc's, from your description there is no tension on that thread.
Posted on Dec 19, 2008
When i use the zig zag stich, sometimes the stich falls and does not zig zag
try a new needle--one for the fabric being sewed
could be a problem with the cam that does the zig zag, you might need to have the machine checked
if your sewing with light weight fabric also try using stablizer
Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
I am having trouble with the thread gathering up on the needle eye then snapping. Can you suggest a solution?
tension is to tight try 1/4 turn to losen use an extra fabric to test the stiches to get it right
Jul 19, 2014 | Singer Sewing Machines
Machine was working stiching, went to stich another piece of fabric and no stiches
Hai, You try to change a new needle Otherwise you take the small waste piece stitched after change the another piece of fabric start a stitching.
Apr 25, 2014 | Sewing Machines
Toyota 100/200 series
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Feb 27, 2013 | Toyota Sewing Machines
MY 18.8 PFAFF WITH IS SKIPPING STICHES I HAVE THE QBOT
Skipped stitches
Jan 12, 2013 | Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
Trouble with the stiching on a juki7800
try changing the needle, make sure the needle is the correct one for the fabric being used
also adjust top thread tension
Apr 16, 2012 | Juki DDL-8700
When i do gathers on my machine i use the largest sticth,but the gathers r hard to pull. y/
Stitch length of 4, loosen your top tension by half a number and always pull up the bobbin threads.
If you need to gather yards of fabric then get a gathering foot. Janome make one - it looks like this
This foot is for creating soft gathers in lightweight fabrics. The underside of the foot is raised behind the needle and has a thick bar in front of the needle to gather the fabric. This works great to create the gathers as you sew. You can also gather and attach a ruffle onto a flat piece of fabric simultaneously, run the flat fabric through the top groove of the foot and the underneath fabric is gathered and stitched to the top piece, you need to keep the bottom piece feeding smoothly though so it takes practice to guide it evenly. Once mastered it is great to ruffle on valances and cushion frills.
Other option is use a ruffler foot, these will make a little ruffle every 12, 6 or 1 stitch so give a set result, and to obtain a more dramatic gather. They look like this.
The arm of the foot with a C'shape sits over the needle bar of the machine so it is moved up and down to activate the device. The little blade at the front moves backwards at regular intervals forcing a "tuck" of fabric into the feed to be stitched. Again you can ruffle and stitch to straight fabric at once but it is an art to master.
The weight of the fabric you are gathering is obviously the key variable, ginghams and poplins are lightweight so gather easily but if you need to gather something heavy like cordoroy it is going to be a battle and threads may break. If so, stitch two lines of gathers and don't try to do long runs, you'll just break a thread and have to start over.
Another good way is to zig zag over a length of perle cotton, taking care not to actually stitch the pearle at all. You can then gather up the fabric along it, this works well for heavier weights.
Oct 22, 2011 | Janome Memory Craft 9000 Computerized...
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
Yamata FY14U4AD Logo
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
