Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
How can I activate the USB 2.0 port? - EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
    Brigadier General:
  • 5,158 Answers
Check that it is turned on in the bios
Posted on Dec 19, 2008
What are the steps to activate movies from usb port on my lg 50pg60ud model
50pg series cannot activate movies via usb
mainboard is not capable of doing that 50Pq series were the first to do this
Aug 17, 2014 | LG 50PG20 50 in. Plasma HDTV
Does this have a 3.0 usb port?
Memory Module Specifications Total Memory Size 6GB Memory Type DDR3 Monitor Specifications Display Type Active Matrix TFT Color LCD Screen Size Connection Type HDMI Maximum Resolution Touch Screen No Media Ports LAN Ports 1 - RJ-45 Ethernet Connector USB Ports (Total) 4
USB Ports Powered (Included In Total) 2x USB 2.0, 2x USB 3.0
Audio Out Jacks Processor Specifications Processor Brand AMD Processor Class A6 Processor Number 5200
Processor Speed 2 GHz Hard Disk Drive Specifications Hard Drives Included Capacity Interface ATA Hard Drive Types Hard Disk Drive
Apr 26, 2014 | Acer Aspire Z Series All-in-one Touch PC...
Usb ports do not work
I have a 24" Dell monitor with built-in USB and SD sockets. Sometimes I have had problems with these not being responsive. This usually comes down to electrical connection.
You should do these in order, also testing for USB port availability at each step .
#1 is the monitor powered up? (USB is active only when monitor is switched on with power button on front of bezel)
#2 check that the USB cable at both ends is plugged in! (you need electrical connectivity)
#3 check that the USB port on the PC can see another device like a memory stick
#4 check your PC's software (drivers must be loaded and the USB port recognized)
Sep 25, 2012 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
We have recently purchased an Intel I7 processor and installed it into the ASUS P6T motherboard. We have also installed Windows 7 OEM builders operating system (not an upgrade version over windows XT). The...
Run "Windows Update", to see if it will find updated device-drivers for the specific USB hardware on the motherboard.
Access the ASUS web-site, and search for 'P6T', and search for USB device-drivers for Windows 7 -- if none are found, try the device-drivers for Windows Vista.
Jan 22, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
Mouse and keyboard have no power
If your mouse and keyboard work properly with another computer or laptop the problem could be :
A) if devices are USB :
- defective USB port : chose another USB port;
- USB port inactivated in BIOS : check and activate;
- motherboard defective : replace motherboard.
B) if devices are PS/2 :
- damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
- motherboard defective : replace it.
Oct 04, 2009 | Computers & Internet
Activate usb port for my computer
you need to install update then windows XP to service pack 2...
The USB drivers are there in service pack 2...
Mar 21, 2009 | E-Machines emachines (emachinees) CD-ROM...
My Dell PowerEdge 2500 has 2 configurable com ports which are setup as Com1 IRQ-4, and Com2 IRQ-3. My problem is that everything seems to say that they are there and active, but my software only can talk...
That "in-op" COM port is in fact, probably defective. Had many cases where 1 works/1 doesn't. Buy a cheap, PCI COM port board, install the software, and plug away!
Mar 19, 2009 | Dell PowerEdge 2500 Server
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Change from usb to ethernet
the ethernet port will already be active
Dec 18, 2007 | Arris SURFboard SB5120 Modem
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
