Question about Nokia N81 Smartphone
DOES NOKIA N81 8GB HAS A SLIDER TO GO DOWN? - Nokia N81 Smartphone
  • cj16514 Jan 26, 2009
    HI, I JUST BOUGHT NOKIA N81..ND FOUND DAT DER IS REALLY A PROBLEM WID ITS SLIDER....wen u press it jst arnd d navi wheel....its feel losse..is dere ny solution 4 it...
  • 20 Answers
NO.
Posted on Dec 19, 2008
The display goes off when the slider is opened on nokia 6210, with slider off the phone works fine
Hi Gaurav,
this seems to be a problem with the cable which connects the motherboard and the display in slider phones. You will probably have to get the cable changed at service centre and I would recommend you to go for original cable at authorised service centre.
Oct 29, 2013 | Nokia 6210 Navigator Cell Phone
Tip
How to disassemble a nokia n95
First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.<br />Now move the slider up and remove the two screws at the top of the phone.<br />Run your fingernail along the edge of the join of the front cover to unclip it.<br />You should now have the front cover removed. The keypad should be loose as well.<br />Flip the keypad part back to access the ribbon which connects the LCD to the phone.<br />To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.<br />Pull the LCD in the direction like you are sliding the screen up.<br />You can now replace the screen.<br />Reverse the whole procedure for reassembly.
on Jan 10, 2011 | Nokia N95 Cellular Phone
How can i unlock my nokia 5800 . i slide the keypad down and it says ''slide keypad down to unlock '' i even took the memory card and battery out but still doesn't work ?
In Nokia 5800 there is slider key on left side wall of you handset.Press and drag it to down ward once to Unlock and to Lock Drag it once again .
Aug 16, 2011 | Nokia 5800 XpressMusic Smartphone
N95 slider problem . LCD goes blank on sliding . it appears that there is problem in Strip. do u get separate strip or it comes alongwith slider....
No the Slider strip doesn't come separately because the strip is merged permanently to a circuit that has your earpiece ,light sensor,and front camera you cannot seperate it in any manner because the only unlockable part over there is the LCD screen .i would recommend you to get your phone serviced from nokia care only because the strip is the most important part in a slider .. even if you get a local strip installed from a local mobile repair center it wont last for a month ..even i had the same problem 4 months back ..because quality of the strip matters .......
Dec 28, 2010 | Nokia N95 Cellular Phone
I cant hear voice over the ear piece
you need to change the flat cable the one that goes to the screen because its the one that supplys voltage to the Earpiece .
Because of the sliding everytime it gets damaged or dropping down also does damage it
The earpiece is still fine .
May 25, 2009 | Nokia 5200 Cellular Phone
N81 8gb,keypad lock switch not working
check kep pad connector
or - chnga ic
Mar 26, 2009 | Nokia N81 Smartphone
Nokia 6500 slider need restriction code
yes need it unlocked i sell unlock codes here!
blackberriesrus.com
Feb 26, 2009 | Nokia 6500 Slide Cellular Phone
Nokia E65 slider doesent work
there is no micro switch.. but there is sensor intalled... i suggest that you check the ribbon connector it is a thin plastic with copper lines on it...
Feb 09, 2009 | Nokia e65 Cellular Phone
Nokia N80 Slider
i think it sort of hardware problem, like slider sensor s not working, u shuld take it back frm wer u got it repaired to fix that problem
shuweb
Mar 06, 2008 | Nokia N80 Cellular Phone
Runners on a slider
okey take it to the nearest mobile vendor.. who repairs.. it just need to place properly. you can try it by reversing the slider mechanism. but be careful. better take it to any mobile repairing shop and get it repair in 5-10 min.
or wash it with petrol by switchhing it offf
best of luck
Feb 08, 2008 | Nokia 6288 Cellular Phone
Nokia N81 Smartphone Logo
85 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
