Question about GE 19GT270 19" TV
LG CA-20F80 TV Defaults to menu 2
I was recently given one of these TV from a motel who was replacing all their sets, it is fantastic condition but I have a problem. It is set to there model as the sound won't go higher than 30 and the menu goes to menu 2. Menu 1 is the one to turn in the stations.
Is there a way to get to the tuning option or reset to factory defaults? Please help if you can Cheers
  • 556 Answers
SOURCE: GE 27GT271 locked onto satellite mode?
Is there a way to unlock the satellite setting? no. Will we have to sign up for satellite for a month or so, so that we can unlock it? yes I do not know about your place I stay in INDIA & here unless you subscribe you can not see cable channels. Or are we just out of luck on this?
Posted on Oct 01, 2007
Agent Jason
  • 78 Answers
SOURCE: POSESSED TV//SOUND MUTES M-F @ 9:30 AM//NEVER ON SAT OR SUN//HELP
Hi doncat01,
Many stations broadcast seperate audio channels to allow commentary or alternate languages to be heard if desired. If this setting has been altered in your television, it would explain why this happens on schedule, as it would be associated with the programming at that time. I recommend navigating your audio settings and looking for "SAP." If this is selected, turn it back to "Stereo," "Mono," or whatever other option is applicable to your audio setup.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jul 23, 2008
  • 29 Answers
SOURCE: screen keeps flashing in and out. Buttons on TV
unplug tv take batt, out of remote then try tv only
Posted on Aug 19, 2009
SOURCE: Cant get any channels between 34-98
If your remote does not have a menue to access auto channel programing, look for it on the TV itself. It may be hiding behind a small panel door, usually toward the bottom of the tv.Once you find it you may have to figure out how to bring the screen up that has programing feature. The screens usually can be brought up by channel or volume controls. Once the auto programing feature appears you push or press ok. If that does not work you should be able to manually key in each channel, one at a time. There as many variations as tvs. Hope this helps. Good luck. Larry
Posted on Aug 25, 2009
  • 139 Answers
SOURCE: THe tv is stuck on channel 11 and I can't get the
The sets have bad eproms. They cause all kinds of problems. also the ground connections around the tuner and microprocessor and eprom need to be resoldered using a silver solder alloy.
Posted on Jan 10, 2010
Hi there I have a LG esnw126 inverter,when I set it on cooling it doesn't run at all.the cooling indicate light is flashing 6times and flashing 2 times on the heating indicating light...help please
Our AC has had a lot of trouble over this summer and we recently had an issue just like yours. We ended up calling an air conditioning repair technician and had it resolved. It was the best thing that we did this summer because it is really hot right now but inside it is great! Ontario CA Air Conditioning repair Penny Plumbing
Aug 24, 2015 | LG Heating & Cooling
What's your question?LG CZ-20F80 TV when you auto search channels it pick up all the channels. When its finish there's no channels locked
Main system control memory IC fault. Replace it. Contact any service technician. The component will look somewhat like this.
25829926-12b3ficbo1zx1xqun0mdlqz1-4-0.jpg 25829926-12b3ficbo1zx1xqun0mdlqz1-4-2.jpg Can be located very near to the main system control IC at the main board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 20, 2015 | Televison & Video
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Tv turns on but no picutre, no menu... and then tv proceeds to turn it's self on and off, on for 10-15 seconds and then off for 2-4 seconds and then back on.... Is there some type of manual reset button on...
Hello
Just set it to factory defaults first. Setting it to cactory defaults, will reset all the items except picture settigns. Parential password will also be get resetted. You have to set it later. To reset the TV to factory defaults, do the following.
[1] Push Menu button and select Setup.
[[2] Select Reset To Defaults from the drop down window.
[3] Push OK button.
The TV will reset to factory defaults and will display it. After that it will switch ON again. Ok
Jan 29, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
How do i find the factory reset?
This model has what is called the "option" menu which is a hard reset of the set. It returns the set to the condition it was when new in the box---on air band on channel 3.
What is reason you want to do the reset? I can tell you how if a good reason.
If this helped you rate this solution as very helpful as I do this here for free and respond with a comment here.
SD TECH
Sep 03, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Need a clone box for multiple Panasonic ct 2522 he televisions
You can get your Panasonic Tv out of hotel mode with the Regular remote control you got with them.
Please follow the steps below.
Press and hold the V/- button on the tv itself.
while you are holding this button down, with the Panasonic remote you got with them press the AV button 3 times.
This will bring up a hidden Installer Menu this is where you can take off the HOTEL MODE. and set up your owe setting.
While you are in this mode, be very care you are not switching things off that you are not sure what they are. as this may put a spanner in the works
Hope you get this all sorted out.
Little Dish Fitter
Please leave a thumbs up if this sorts you out....
Jun 29, 2009 | Panasonic ET-RM100 Remote Control
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Feb 27, 2008 | Televison & Video
GE 19GT270 19" TV Logo
77 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
