Question about Marantz PMD670 Desktop Digital Voice Recorder
Marantz PMD671 recorder - download problem
How do I download a recording from the media card to my mac? Nothing registers on my computer when I connect to the recorder via usb... When I connect my Marantz recorder to my PC with the USB cable, it allows me to transfer files to the PC.  However, when I do the same thing with the Mac, nothing happens.  My Mac doesn't recognize it at all. Hi there,
I've just bought a PMD671, and am have a lot of trouble with USB connectivity. I've tried 3 different computers (HP XU800, Lenovo S10 and IBM T43), and 4 different OS and BIOS combinations (Win98SE, Vista64, and two different USB-BIOS-enabled DOS boots.
In all cases, I can read 5 different USB drives I have from Sandisk (3) and Kingston (2), as well as my Olympus E1 digital camera and my wife's Canon Ixus - but the Marantz PMD671 usually just causes my BIOS-equipped PCs to hang during boot up, unless and until I turn the recorder off or pull the plug.
In Win98SE, where I use generic USB drivers (from Kingston), the "new device" recognition phase simply hangs - again, until I turn the PMD off or pull the plug.
Once in a while - say one time in about 10-20 - when I turn on the USB, my Vista 64 machine sees it and pops up the "Autoplay" dialog; likewise, this same machine sometimes gets through a reboot with the BIOS recognising the PMD, which then gives me direct access from DOS.
But it's so hit and miss - is there anything I can do to make it work every time, rather then once out of a dozen or more attempts?
  • cattlejam Mar 28, 2009
    I have the same problem, except that nothing happens. Nothing at all.
    My PC doesn't even recognized that I've plugged in a new device.
    Mine is a PMD671.
5 Suggested Answers
1Guru
  • 61 Answers
SOURCE: marantz PMD671 recorder - download problem
I need to know what model mac you have. This would help. Also what operating system you are using. Older macs may not be compatible unless you update the system. The latest macs with the intel chip work fine with this. Once quick solution is to update your software to the latest versions by going to your apple with your mouse in the upper left corner of your screen and then clicking it. Scroll down to the title software update. click that and then click update now. Check the boxes of all you want to update and then hit enter. *Note: you must be connected to the internet in order to make these updates. I would suggest being connected something faster than dial up.
After you have done your updates, try to reconnect the Marantz. Remeber to connect it first then turn it on.
Another solution is to format the card on your mac first by using a card reader and the program Disk Utilities located in your utilities folder. It is important to choose the Fat 32 format (You will see this in your pull down menu). Note: This will erase everything on your card.
If you have a card reader, you can always take the card out of the recorder and try to read it that way as there may be a communication issue with the mac and the recorder, but if it can be read on the PC and not the mac, I doubt that is the issue.
Posted on Dec 08, 2008
SOURCE: MARANTZ PMD 101 PROBLEMS, COUNTER AND REWIND
Get the belts changed, and check a clutch inside the mech which drives the auto-stop mechanism.
It works in a way that it normally holds the auto-stop off if the spools are rotating, but when it wears, there is no srive through it to hold the auto-stop off, so the auto-stops stops, if you see what I mean.
Any good audio tech should be able to do this, if the machine otherwise works OK, it is worth doing because these are very nice and usually reliable machines.
For musical work though, the CP series are usually better, as they provide 3-heads and off-tape monitoring, with better quality and the facility to set tape bias to suit high-grade tapes.
Posted on Apr 15, 2009
SOURCE: where can I get manual for Marantz PMD-221
I have manuals for the Marantz PMD 201/PMD221 and the 420/430.
Michael
Posted on Jul 10, 2009
tscmusa
  • 95 Answers
SOURCE: I cannot see the MPLANG FILESto transfer to PC?
save your recordings and do a hard reset on it,if that doesnt work,it may have to go to marantz or a dealer for service
Posted on Apr 01, 2010
Can't import to my mac
The CX-R190 is not designed to be compatible with the Mac. However, if the recordings you want are on the microSD card, you can simply remove the card from the recorder and insert it into a card reader (either built-in to your computer or connected via USB or FireWire) and copy the files the same way you copy any other files on your Mac.
Mar 31, 2012 | Coby CX-R190 Digital Voice Recorder
When I press record, it says Err Card 1. I've tried a new card and formatting. Any ideas?
Sorry to say that it's clear that this Marantz recorders develop this problem over time and Marantz has offered no solutions. When I first purchased this recorder it was enormously reliable and stable, but I find now that it is totally the opposite -- often it has recorded for a while and then suddenly develops an inability to read the SD card and so either quits recording or freezes up.
There seems to be no clear solution to this, and the random nature of the problem makes the recorder wholly unreliable in a live or field setting. This is, sad to say, unacceptable.
May 23, 2011 | Marantz PMD620 MP3 Player
How to format a new CF Card without getting a display message that says "must format on PC"?
I have this same problem. I have 3 cards. 1 of them my Marantz PMD671 just doesn't like, and produces the error message "you need format on PC". I can format it on PC, and use it normally, but the PMD671 will not have it. The card is a cheapo Dane-elec.
I give up at this point.
Apr 22, 2010 | Marantz PMD670 Desktop Digital Voice...
Cant get mp3 files from my marantz pmd620 to play on my mac
Well, try copying them to a folder on your computer. Also, make sure that the files are not proteced with DRM. If these fail, open iTunes. Select all of the MP3 files and drag them into your library. That should fix it.
Feb 04, 2009 | Marantz PMD620 MP3 Player
I have a Marantz 660 - when I tried to download a recording the icon didn't come up on the computer- it did the first time and I was able to download but it didn't work the second time.
Hi. I use mine with a Mac. The instructions say it's the same for PC. From the 'off' position, plug in the usb cable to the computer, hold down the 'copy/ usb' button and switch it on. The display will read 'usb' and the icon -"should" appear on the desktop. Open the folder and look for files with machine ID. Failing that, try new usb cable? or the techies favourite: "switch everything off and start again" LOL
Dec 15, 2008 | Marantz PMD660 Digital Voice Recorder
Recorder stuck on "BlankCard"; won't record
Hello if you need any further assistance please message.
Sep 27, 2008 | Marantz PMD670 Desktop Digital Voice...
Aug 29, 2008 | Marantz PMD660 Digital Voice Recorder
Marantz pmd670 4 Gig Card formatting problem
No solutions, Marantz it´s a very old technology
Apr 12, 2007 | Marantz PMD670 Desktop Digital Voice...
Marantz PMD670 Desktop Digital Voice Recorder Logo
317 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
