Question about Pioneer DEH-P5800MP CD Player
DEH P5800MP No power
I have had this stereo installed in my car (85 Corvette) for 6 months with no problem. The power antenna motor wouldn't turn off so I disconnected the wiring to it; when I did this the head unit and interior lights would not get any power either. I reconnected it, but stil nothing is getting power. I checked all the wiring and fuses that I can get to, but I no longer have the keys, so I can't get the head unit out of the dash.
On alot of vehicles, the power ant and/or illumination wire for the factory radio ties into the "courtesy circuit". Normally, the scosche factory plug adapter takes the proper action with this wire. For custom install, sometimes it's needed to ground this wire, sometimes it need be tapped into the deck's "remote" (blue) wire, and sometimes it need be left alone! Example, on a 1987-1993 S-10 pickup, you need to connect the "ill" wire of the aftermarket deck to this (usually orange) wire in the dash, or you'll have no dome, dash, or running lights... hence "courtesy circuit"!!! hope thius helps!!!! and footnote, its always good to hook this wire up as most decks nowadays will have an automatic dimming feature that senses the voltage of the dashlights being on... so at night when you hit the headlights, the deck will dim to ease the eyballs.
Posted on Nov 03, 2007
When you get the keys, or whatever try unhooking the power antenna wire as it comes out of the back of the stereo. Otherwise your guess is as good as mine.
Posted on Apr 12, 2007
I need the radio wiring color diagram for my delco radio, 1998 corvette
1998 Chevrolet Corvette Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakers
Front Speakers Location: Kick Panels
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6?
Rear Speakers Location: Rear Sides
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 22, 2016 | Cars & Trucks
I'm installing an after market radio on my 82 vette, but i don't know which is the power lead for the power antenna. anyone know?
Usually the blue wire from the stereo is for the remote amp and/or power antenna. If you haven't cut off the stock radio plug, I would check into getting a stereo harness adapter for the stereo. Most auto stereo shops can get them.
Apr 27, 2010 | 1981 Chevrolet Corvette
Pioneer DEH-P5800MP CD Player not powering on.
did you try the fuse behind the wireharness. if so check the yellow wire and the red one for power. also check if you have ground on it. if you want to make things simpler try to connect the black wire to the battery neg. and the yellow and red together on the positive of the battery and see if it turns on.
Sep 01, 2009 | Pioneer DEH-P5800MP CD Player
DEH-5800Mp Button lights wont turn off when the ignition is off
Try installing a toggle switch to cut the power and the light may be on because you have the illumination wire hooked up.
May 16, 2009 | Pioneer DEH-P5800MP CD Player
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
Need wiring diagram for harness
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
May 04, 2009 | Car Audio & Video
Dehp5800mp wire harness
orange /white wire is power antenna wire i think.is your setup working????????.let me know the status..
Jan 06, 2009 | Pioneer DEH-P5800MP CD Player
I am getting no Power to my DEH-P5800MP
CHECK IF THE YELLOW WIRE IS CONNECTED TO BATTERY POWER
May 15, 2008 | Pioneer DEH-P5800MP CD Player
Pioneer DEH-P5800MP CD Player Logo
128 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
