Question about LG MV-1444Y Microwave Oven
Kenmore galaxy microwave model 721.80002 1500 watts does not heat
Everything else works. won't heat up. sometine makes noise after cook button is pressed. Model appx. 2.5 yrs old. need it for x-mas dinner. please help
  • 1 more comment
  • concernedad Dec 22, 2008
    When I press start it makes a loud noise like something is trying to connect like a loud buzzing noise, the light comes on and the turntable rotates. The only way you can tell that it is not working is to check the food. The model # is 721.80021000 it is 950 watts not 1500 as I thought earlier.
  • stephs0418 Apr 14, 2009
    microwave wont heat up food
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    Can you post the full model number?
    A full Sears/Kenmore
    model number has 3 digits, a dot, then 8 more digits, such as
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • LG Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 22, 2008
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
Sep 18, 2013 | Kenmore 62463 721.62463201 Stainless Steel...
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Not heating and making a loud humming noise.
you have done well out of the oven . it sounds that certain components are well worn and probably no able to get parts best advice it time to buy a new one
Dec 21, 2017 | Kenmore Microwave Ovens
Kenmore microwave stopped heating
simply stated.. if it fails to cook.. you may have either a bad magnetron tube ( that's the part that generates the microwave energy that cooks the food) or the filament transformer feeding that magnetron is bad. In either case.. you're probably better off replacing the entire appliance than repairing it.. Hope that helps...
Aug 30, 2008 | Kenmore Microwave Ovens
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Jul 29, 2008 | Kenmore 62622 Microwave Oven
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Dec 30, 2007 | Kenmore 64002 Microwave Oven
LG MV-1444Y Microwave Oven Logo
1,192 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
