Question about Nokia 9300 Smartphone
Front Screen Not working in Nokia9300i
I have a Nokia9300i. Phone is working finw in every aspects but the Front cover screen is powering up with white light only. No display on front screen. The inside Desk Screen (Wide one) is working fine. so i don't think there is a problem with Flex Cable which joints two parts of the phone.
Pls help me out. I have to open the phone everytime for making a call or reading an SMS.
Gaurang
  • Deepak
    Deepak Jan 12, 2009
    Even i have the same problem please help.......
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
I would try to take off the phone covers and take off the screen. You will need a Torx T6 screwdriver or similar to do this. Once the screen is off, you can clean the contacts with one of those plastic pencil erasers. Put everything back together and see how it goes. You will need to be careful of the screen positioning.
I've done this with other Nokias (not had to with my 9300 yet) as I find the dust gets in and collects round the contacts...
If no joy, get a broken 9300 from an auction site or similar, one with a broken internal screen maybe, and have a go at swapping the screens.
Posted on Feb 03, 2009
Hi The aspect ratio on my Thomson Scenium tv (32wb842a) is out, and some shows fall off the bottom of the screen - including the tivo menu! Alas, the remote has never worked, so the manual information is...
the aspect is controlled by the on screen menu
if you can press the buttons on the side of the tv to get that screen menu then you can adjust the screen resulation
Nov 18, 2017 | Televison & Video
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Hi, my lg shine ke970 phone isnt working. I've had it for only 5 months and already the screen has stopped working. The lights on the keys and stuff come on but the screen just stays blank. This has...
Hi
All you need to do is to put off your phone,remove the battery and sim card then loose the phone with a phone screw driver,insert a plastic tool to seperate the screen from the motherboard,remove the old screen,be careful not to scratch or smudge the new screen.
Then place the replacement screen back into the motherboard,then fix the front cover and couple back the phone.
Enjoy your newly repaired screen.
BEST OF LUCK
Aug 05, 2010 | LG Shine KE970 Cellular Phone
Droped my voyager and now the screens are blank
The problem could be that the screws that attached the screen of your phone to it panel might be loose.
All you need do is to power off the phone, remove the battery cover,battery and sim card. turn the phone over and, gently remove the front cover or casing, it just pulls off.
Get a torx6 screw driver to tighten all the screws on the screen of your phone very well and couple back.
Put the sim card and your battery and power on, if the screen did not still come on, it means the flex on the screen of your phone is bad and will need to be replaced.
Replace the flex of your phone screen if tightening the screws of the screen did not solve the problem. change the flex of the screen of your phone and you will see that your phone will display.
Take care.
May 21, 2010 | LG VOYAGER VX10000 Cellular Phone
I droped it and the screen wont turn on
Since you said the phone drop from you, it is possible that the screws that attach the screen of your phone is not tight anymore.
I suggest you get a torx6 screw driver, power off the phone, remove the battery and turn the the phone over.
Carefully remove the front cover of your phone that leads you to your phone screen.
Use the torx6 screw driver to tighten all the screws of your screen very well to the panel of of your phone.
Recouple your phone back, put the battery and power on, the screen should display.
But if the screen did not display, it means the flex on your phone is bad and will need to be replaced.,
So change the flex if tightening of the screen did not work, so change the flex on your phone and your phone will display.
Take care.
May 08, 2010 | Sony Ericsson T715 Cell Phone
My screen is pale and when i press parts of the phone it turns back to the right resolution but it wont do that anymore.
It seems the phone fell from you or you hit the phone surface with a hard surface for your screen to be malfunctioning because it is possible that the screen is not firmed to the panel any longer and you will need to affirm it.
Get a torx6 screw driver.
First thing you need to do is to power off your, remove the baattery, and sim card, Turn the phone over and gently remove the front cover.
After you have pull off the front cover, you can go on with the torx6 screw driver to tighten all the screws that hold the screen of your phone to its panel very well and recouple the front cover back.
Put your sim card and battery to power on, with this it should stop the pale screen.
Take care.
Apr 30, 2010 | Cell Phones
For NO apparent reason my iPhone 3GS's backlight has suddenly ceased to work. All other aspects of the phone work perfectly. You can still see all icons on screen but have to tilt it so light reflects the...
If you havent done any of those things, take it in a nd have it repaired. That should be covered under warranty.
If they tell you they wont fix it, check out the followin glink for a low cost Iphone screen repair service
Repair Iphone 3GS Backlight Problem
Dec 01, 2009 | Apple iPhone 3G
Touch screen not responding
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didt't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
I noticed that on the front cover of the phone (underneath) you can see the copper band of wires that connect to the buttons and probably feeds the information from the touch screen to the 'computer'. I accidentally unplugged the wire (thought I broke it) but was able to insert it back in. I put the the cover back on, put the battery in, power up phone, BINGO! Touch screen works! What I did to make it work? Not sure...
But for people with the same problem. Try this:
1) update ROM
http://www.htc.com/us/SupportDownload.aspx?p_id=70&cat=2&dl_id=98
2) Unplug and plug back in that little wire.
http://img81.imageshack.us/img81/1912/htctouchx.jpg
Its the red circle I'm talking about.
Jul 17, 2009 | HTC Touch Cellular Phone
Touch on touch screen phone not working
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didn't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
1) update ROM
Jul 07, 2009 | HTC Touch Cellular Phone
Hindi font for NOKIA9300i
You need Hindi sms software
but it won't work on ur phone
it's work with s60 phone
Dec 11, 2008 | Nokia O2 9300 9300I Flexible Mini Boom W/...
Nokia 9300 Smartphone Logo
231 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
